Author Topic: So what's everyone using for a frontend ??  (Read 24240 times)
Re: So what's everyone using for a frontend ??
« Reply #40 on: February 19, 2015, 04:41:29 pm »
I'm contemplating changing my vertical arcade cab over to Maximus also.
Just a word of caution, Maximus rotates vertically only one way.  So your monitor needs to be rotate left (with the bottom facing the right side) in order for it to work.  If your monitor is rotated left it will be upside down and you'll need to remove and re-seat your monitor (since there is not option to rotate left in the Front end's software).
D
« Last Edit: February 19, 2015, 05:26:34 pm by DeLuSioNal29 »
keilmillerjr
  • Web Developer.
« Reply #41 on: February 19, 2015, 05:00:49 pm »
The big question I'm concerned with is:  Which Frontend EASILY supports PC games?  With the explosion of Steam Arcade Games I'm looking for a front end that is compatible with Steam's proprietary method of launching games in addition to MAME and consoles.
Anyone?
D
Attract-Mode
mgb
  • North East, US
« Reply #42 on: February 19, 2015, 06:18:03 pm »
D
thanks for the heads up. My monitor is set up with the bottom to the right so I should be good there.
last year, I messed with Maximus on this cab but ended up going back to Mala. I can't for the life of me, remember why. I guess I'll try again.
danny_galaga
  • Last login:Today at 12:38:09 am
    • dans cocktail lounge
« Reply #43 on: February 20, 2015, 06:16:09 am »
Its hard to pass up the incredible amount of content and effort that's been put into HyperSpin.
Yeah, but hyperspin makes my head spin. It's like a vw, over engineered.
You're obviously not talking about MY VW  ;D
« Reply #44 on: February 20, 2015, 06:30:16 am »
I'm not entirely sure which end is the front ;)
mgb
  • North East, US
« Reply #45 on: February 20, 2015, 08:01:39 am »
Nice notchback
AzureKnight
« Reply #46 on: February 20, 2015, 10:32:26 am »
So now we get to the real point of this thread, he must not know either...
"So what's everyone using for a frontend ??"
markc74
  • Flipping out
« Reply #47 on: February 20, 2015, 05:18:32 pm »
Previously I would have said MALA but since getting my head around Attract Mode I'm a convert - it rocks. With patience and a rough concept of how to program the layouts you can make it do whatever you like.
https://www.youtube.com/results?search_query=attract+mode+frontend
I had an ideal frontend layout in my head where rather than pick from a list you had a row of arcades next to each other and you scrolled left and right to 'walk' down the row to pick to the game you wanted to play while still seeing the games on either side (rather than scrolling through a text list) and Attract mode lets me create that*
I think if attract mode gets more popular we'll start to see themes that can pretty much do what most other frontends do anyway (except maybe hyperspin which is not my cup of cha anyway)
*Disclaimer - I've been a programmer for 20 years so it wasn't a massive jump to learn it.
bfauska
« Reply #48 on: February 20, 2015, 07:36:10 pm »
Yours is one of the most promising ones in the results of that youtube link. Of course since you didn't link directly to it I'm only guessing but since the cabinet is Blip and the games are laid out the way you describe I'm pretty sure it's the one.
I've been using Mamewah in my cabinet for years but since I'm planning on doing a PC upgrade (to a still used but less used computer) I am probably going to switch to something more win7 compatible.
I've been playing with Hyperspin on a different computer but it is pretty resource hungry, how's Attract Mode compare in that regard?
ChanceKJ
« Reply #49 on: February 20, 2015, 07:49:55 pm »
Richardgregory
  • Last login:November 17, 2021, 01:15:10 pm
« Reply #50 on: February 21, 2015, 05:14:49 am »
Still setting up Hyperspin, but for most part MAME portion is almost done, but not quite.  Also, have Maximus Arcade as well on the same PC.  I'm using Hyperspin because of the attractiveness of the graphical interface, but then again, simple is not necessary a bad thing such as with Maximus.
bulbousbeard
  • Last login:August 25, 2015, 11:58:25 pm
« Reply #51 on: February 21, 2015, 10:14:03 am »
It's really hard to justify using Hyperspin when we know it interferes with the behavior of MAME.
What's the point of a frontend that can't even run programs properly?
bulbousbeard
« Reply #52 on: February 21, 2015, 10:27:17 am »
There's an incredible amount of bad content. I'm not sure how much good content there is. Really, if you're even somewhat discerning, most of the Hyperspin themes are flat out BAD. The only reason Hyperspin's so popular is because most people have poor taste and can't distinguish good aesthetics from tacky crap. 9 out of 10 themes mix multiple completely different art styles from games made years apart from each other. It's a complete mess.
  • Last login:Yesterday at 03:34:59 am
« Reply #53 on: February 21, 2015, 10:29:24 am »
We "know" that? How so? I haven't had any issues with it running games in MAME.
bulbousbeard
« Reply #54 on: February 21, 2015, 10:44:14 am »
Look at the GroovyMAME forums. You can't even run MAME with triplebuffering and multithreading with it. It's untrustworthy software.
« Reply #55 on: February 21, 2015, 10:45:13 am »
Well there's your first problem: I don't run GroovyMAME....
« Reply #56 on: February 21, 2015, 10:55:38 am »
I run GroovyMAME and it works fine with Hyperspin.
bulbousbeard
« Reply #57 on: February 21, 2015, 11:03:45 am »
Even standard MAME has the same problem. Really, people have such a high tolerance for poor performance, it wouldn't surprise me if the people who "have no problems" are actually experiencing them but are just clueless.
« Reply #58 on: February 21, 2015, 11:10:58 am »
Well, if a problem isn't perceived, is it really a problem?
bulbousbeard
« Reply #59 on: February 21, 2015, 11:18:23 am »
Yes. I mean, there are people in this forum (whom you'd expect to be a little bit savvier) who actually make the argument that running games at the wrong refresh rate is unnoticeable.
« Reply #60 on: February 21, 2015, 11:42:12 am »
bulbousbeard
« Reply #61 on: February 21, 2015, 11:57:22 am »
I think it's more like:
« Reply #62 on: February 21, 2015, 12:04:47 pm »
jukingeo
  • Last login:March 14, 2015, 08:25:28 pm
« Reply #63 on: February 21, 2015, 12:34:44 pm »
Ok, in Windows, my favorite overall front end is currently Mala.
I do like the overall look of Hyperspin, but the need to have a larger machine just for the front end just didn't justify it.  Otherwise if I did have a more powerful machine I would revisit that.
Before Mala, I had MameWah for the longest time.
I Linux I like to use MameWah's cousin, Wah Cade.
"Let me tell you about the time I used a sharpened clamshell to turn a T-Rex into a T-Rachel!" -Buck  Ice Age 3
« Reply #64 on: February 21, 2015, 12:45:15 pm »
I currently use MaLa, havent really updated MAME or Roms in a while, and MaLa is cray cray easy to make skins for.
I looked at attract mode but I glanced at what it takes to make a skin, and I dont have that kind of time.  I looked at big blue, but Its not skinable (yet?) and I dont want the built in game.
MTPPC
« Reply #65 on: February 21, 2015, 12:50:15 pm »
D
You can always flip your yoke wires to get the right orientation.
http://pinballmd.com/
mgb
  • North East, US
« Reply #66 on: February 21, 2015, 01:50:40 pm »
Just a quick question on Maximus.
Are unlock codes still being generated
« Reply #67 on: February 21, 2015, 05:20:48 pm »
MGB - depends who you ask. It's hit or miss. But now that the author has partnered with XArcade he may have gotten his act together. YMMV.
otsep
  • Last login:September 28, 2025, 02:53:45 pm
  • I'm your huckleberry...
« Reply #68 on: February 21, 2015, 05:33:48 pm »
I'm a HUGE VW fan and that is beautiful.
Vids: Namco Rockin' Bowl-O-Rama
Pins: Aerosmith Pro, ST Premium Vault, Beatles Gold
Remember Wheaton's Law
knightrdrx
  • Last login:June 06, 2020, 10:45:36 pm
« Reply #69 on: February 21, 2015, 09:14:03 pm »
I've been working on Maximus Arcade for almost a year. I keep changing my mind about stuff..adding new games etc...but I'm going to wrap it up this week so I can just relax and play.
When I add new games the game lists get messed up. It's annoying but I won't change to anything else at this point.
And I like that I can leave it on the main menu and not have a video running while I leave the room.
It supports everything I want.
« Reply #70 on: February 21, 2015, 10:25:24 pm »
I abandoned Maximus ages ago. But how do you get Steam games to work with their proprietary URL shortcuts?
WindDrake
  • Last login:December 03, 2020, 09:49:05 pm
  • Electrical Engineer
« Reply #71 on: February 22, 2015, 04:26:11 pm »
I've been using GameEx for the last couple years. Works great.
Fursphere
  • Last login:Yesterday at 11:52:38 pm
« Reply #72 on: February 22, 2015, 05:12:49 pm »
Just point to the game EXE instead.
« Reply #73 on: February 22, 2015, 05:25:04 pm »
That doesn't work with some Steam Games.
bulbousbeard
« Reply #74 on: February 22, 2015, 06:25:39 pm »
As far as I know, Big Blue will run anything that can be run from the command line. Haven't encountered any program that it can't run.
Yup, works perfectly in Big Blue without any batch files or ---That which is odiferous and causeth plants to grow---.
Big Blue doesn't care what the program is. It will run anything.
« Last Edit: February 22, 2015, 11:13:21 pm by bulbousbeard »
Fursphere
« Reply #75 on: February 22, 2015, 10:30:56 pm »
Ok, I figured this out for ya.
Step 1 - Right click on game in Steam and "create shortcut on desktop"
It should look something like "steam://rungameid/282440"
Step 2 - Create a batch file (plain text) called something like "game.bat"
Step 3 - In the batch file put "explorer.exe steam://rungameid/282440"
Step 4 - Point front end at the batch file you created.
If Steam isn't running, but is registered properly, it'll start Steam then start your game.
(steam://rungameid/282440 is Quake Live on my system - don't know if that's universal or not)
Enjoy!
ahofle
    • Arcade Ambience Project
« Reply #76 on: February 23, 2015, 12:31:48 am »
Can you elaborate on the issues with refresh rates with GroovyMAME and hyperspin?  I run that configuration with correct refresh rates, resolutions, etc using MAME's ini files.
danny_galaga
« Reply #77 on: February 23, 2015, 02:53:26 am »
BCThunder
  • Last login:May 27, 2017, 06:07:23 pm
« Reply #78 on: February 28, 2015, 08:03:15 pm »
I recently put together a computer for my 8 year old, and found a great front end called Launch Box.  It has some great features like importing box art from thegamesdb.net, and the ability to import games from your Steam Library.
mgb
  • North East, US
« Reply #79 on: February 28, 2015, 08:47:08 pm »
I was just recently trying that one out too. Very nice for consoles
