Author Topic: Spectrum in wolfmess  (Read 1624 times)
empardopo
  • Last login:January 18, 2026, 03:32:00 am
    • My personal forum
« on: February 04, 2015, 06:18:39 am »
Anybody has configured the spectrum emulator using wolfmess?
I get record the game and It's OK. My problem is how can I see the recorded game then?
To record the game I use this command line
Code: [Select]
mess spectrum -snapshot "software\spectrum\Manic Miner (1983)(Bug-Byte Software).z80" -record manicminer.inp
Now, I have the file manicminer.inp
How can I see it?
Thanks in advance.
Tafoid
  • Last login:February 12, 2025, 04:47:22 am
  • Emulation Devotee
    • MAMELOAD TNG (Front-End)
Re: Spectrum in wolfmess
« Reply #1 on: February 12, 2015, 10:53:37 am »
Code: [Select]
How can I see it?
Thanks in advance.
Use the same command as above, but use "-playback" instead of "-record" to watch it in action.
empardopo
    • My personal forum
« Reply #2 on: February 16, 2015, 02:51:44 am »
Code: [Select]
How can I see it?
Thanks in advance.
Have you tested it? It doesn't work!
