Author Topic: Talk me into/out of buying this Laminate Trimmer.  (Read 4866 times)
« on: January 18, 2015, 05:42:34 pm »
So I saw this today at Lowe's and think it's a pretty good deal.
http://www.lowes.com/pd_496568-70-DWE6000_0__?productId=50146264
I want to ensure no chips when I do laminate on my cab(s) but I certainly don't want to drop a hundred bucks on a unitasker...
I'm sure I can use this for other stuff?  Slot cutting maybe? Recess mount sticks?
What do think?  Worth the money?
Re: Talk me into/out of buying this Laminate Trimmer.
« Reply #1 on: January 18, 2015, 05:57:07 pm »
That should be a decent router if you are on a budget.  You should have no issues trimming laminate.    I have the kit that is a step up from that one and it is one of my favorite tools.
http://www.lowes.com/ProductDisplay?partNumber=473808-70-DWP611PK&langId=-1&storeId=10151&productId=4542280&catalogId=10051&cmRelshp=req&rel=nofollow&cId=PDIO1
You will be limited to 1/4" bits but I have not found that to be an issue with mine thus far.
« Reply #2 on: January 18, 2015, 06:07:35 pm »
I have a palm sized one comparable that and I do everything with it.  R2 was built with a router that size.  You'll be fine.
« Reply #3 on: January 18, 2015, 08:14:07 pm »
Thanks guys. Added to wishlist.
behrmr
« Reply #4 on: January 20, 2015, 10:04:09 am »
If you want a unitasker then just get the $29.99 1/4" trim router from Harbor Freight.  It works fine and I've done 3 cabinets with mine and no chipping.  Just buy a good laminate bit.
http://www.harborfreight.com/power-tools/routers/1-4-quarter-inch-trim-router-44914.html
otsep
  • Last login:September 28, 2025, 02:53:45 pm
  • I'm your huckleberry...
« Reply #5 on: January 25, 2015, 09:37:18 am »
+1 for the DWP611PK.  I have the kit and use the hell out of it.  The trimmer technically is a router, but pretty much set for trimming.
Going for a real router gives you a better housing, depth adjustments, collet, etc.
Routers are like tattoos; Cheap ones aren't good, good ones aren't cheap.
Vids: Namco Rockin' Bowl-O-Rama
Pins: Aerosmith Pro, ST Premium Vault, Beatles Gold
Remember Wheaton's Law
Fursphere
  • Last login:Yesterday at 05:52:53 pm
« Reply #6 on: January 25, 2015, 08:16:49 pm »
Just remember that DeWalt is owned by Stanley Black and Decker.
There are a few DeWalt branded tools with identical Black and Decker counterparts (different colors) for a fraction of the price....   :cheers:
« Reply #7 on: January 25, 2015, 11:01:32 pm »
You have to watch them carefully though as sometimes they don't offer the same features. The Porter Cable equivalent of the  DWP611PK does not have a variable speed switch nor an LED work-light for example.   If you don't need the missing features you can indeed save some money.
http://www.amazon.com/PORTER-CABLE-450PK-Compact-Router-Plunge/dp/B0046A8V6A/ref=sr_1_17?ie=UTF8&qid=1422244688&sr=8-17&keywords=porter+cable+router&pebp=1422244695794&peasin=B0046A8V6A
otsep
« Reply #8 on: January 26, 2015, 12:42:29 am »
Spot on.  For the extra $6 I would got the the variable speed control and LED.  The control is important as some bits have speed limits.
http://www.amazon.com/DEWALT-DWP611PK-Torque-Variable-Compact/dp/B0049ZFUK2
Minwah
    • MAMEWAH
« Reply #9 on: February 06, 2015, 10:25:22 am »
I bought this one and love it:
http://www.amazon.com/Makita-RT0701CX7-1-1-Compact-Router/dp/B00HAQMHEO/ref=sr_1_2?s=hi&ie=UTF8&qid=1423235688&sr=1-2&keywords=Makita+RT0700
I bought it with just the fixed base for £100 (I bet that would be <$100 in the US). Not sure if you can still get it without the plunge base, but they used to sell it with different bases.
I should add that I've since bought the tilt base and plunge base, as I find the router so useful. I do all of my routing (laminate trimming, slot cutting, edge trimming, plunging etc) with it.
a1pharm
« Reply #10 on: February 13, 2015, 06:59:22 pm »
Just get a flush trim router bit and a regular router if you want to avoid the "unitasker."
