Author Topic: Stick upgrade  (Read 2949 times)
concor
  • Last login:January 16, 2015, 04:55:23 am
Stick upgrade
« on: January 15, 2015, 06:11:09 am »
Hi there, I'm new with arcade sticks.
I ordered the stick below and was hoping I can exchange the stick and buttons with Sanwa ones. Is that possible? I think it will fit, but will it work as well?
Stick I ordered: http://www.aliexpress.com/item/Acrylic-panel-rocker-arcade-rocker-computer-arcade/1201271947.html
Sanwa stick I want to throw in: http://www.ebay.com/itm/NEW-ORIGINAL-SANWA-JLF-TP-8YT-JOYSTICK-FOR-ARCADE-GAME-1-RED-BALL-TOP-HANDLE-/181204034505?pt=LH_DefaultDomain_0&hash=item2a309a23c9
I think the screw holes line up:
keilmillerjr
  • Web Developer.
Re: Stick upgrade
« Reply #1 on: January 15, 2015, 09:02:58 am »
If it doesn't fit, the top panel looks like it is just a flat peice of acrylic with holes to screw down and secure. Should be very easy to replicate if need be.
  • Last login:Yesterday at 12:55:58 pm
Re: Stick upgrade
« Reply #2 on: January 15, 2015, 04:22:08 pm »
Keep in mind that e-Bay listing is coming from China, so it might a few weeks to get to you.
Have you checked out the same joystick here?  http://www.focusattack.com/sanwa-jlf-tp-8yt-joystick/
You can use your existing ball top on it (screws on and off) but if you want a new ball top it will be an additional $2.95 - But you can choose whatever color you want.  They are located in the continental US (PA on the East Coast).
D
concor
Re: Stick upgrade
« Reply #3 on: January 16, 2015, 04:55:23 am »
Thanks for the replies. It looks like there is nothing technically challenging to this upgrade. If I understand it correctly the sticks and buttons just have switches and no other electronics in them. As for the wiring, the sanwa wires are super simple. Just 4 directions and a ground. I like how simple this arcade stuff is!
As for the focusattack link, thanks for thinking along, but I am in Holland and shipping from the US is there 22 usd. I think I'll get them from https://www.akishop.jp/ or ebay.
I scaled the two blueprints on top of each other and they seem to fit alright. I will just makes some extra holes in the sanwa plate if it doesn't:
stripe4
  • Last login:January 05, 2025, 04:19:54 pm
    • forum.arcadecontrols.com/index.php/topic,129541.0.html
Re: Stick upgrade
« Reply #4 on: January 16, 2015, 08:20:06 am »
There are quite a few vendors in Europe, too. One of them happens to be in The Netherlands:
http://www.arcadewinkel.nl/besturing/joysticks/balltop?page=2
Others to condiser:
http://www.arcadeshop.de/
http://www.arcadeworlduk.com/
http://shadaloo.eu/
http://www.starcab.net/
