Author Topic: Exit Model2 usint A-pac with mala  (Read 3869 times)
gpzjack
  • Last login:January 15, 2015, 08:46:25 pm
« on: January 14, 2015, 09:37:41 am »
I've been using mala forever and find it pretty easy to use. This time i've built a full sit down racing cab and i'm using a a-pac with it. The only problem i've run into is that i usually use a hotkey to exit sega model 2 but since i'm using a a-pac it won't recognize any of the button inputs.  Can someone help me out?
thanks!
Upright Cab. Future Pinball Cab. Working on Sit down Racing Cab. :)
Re: Exit Model2 usint A-pac with mala
« Reply #1 on: January 14, 2015, 10:39:32 am »
I had to use a program called closemul with Model 2 and Mala
It's covered in UncleT's setup guide stickied here IIRC.
The one oddball thing I remember is having to put closemul.exe and a space before my model 2 command line.
(instead of putting it in the pre-command box above)
gpzjack
« Reply #2 on: January 14, 2015, 10:42:08 am »
thank you. I usually use x-arcade controllers so its been pretty easy. I wanted a little more of a challenge this time so i did all the wiring. I'm loving it so far :)
empardopo
  • Last login:January 18, 2026, 03:32:00 am
    • My personal forum
« Reply #3 on: January 15, 2015, 02:05:51 am »
AllInOneFYC could be useful for you.
Greetings.
