March 01, 2026, 06:42:33 am
UPDATESREVISION D (used on most Popeye machines) : information First level has a black background.information Default high score is 32,600.information First nickname on the default high-score table is GET.information Spinach can only be used once per level, and it is not restored after you lose a life.information The ladder at the center of the first level can only be used to go down.information Extra Life dip-switch can be set at 40,000, 60,000, 80,000, or None. The default is 40,000, meaning you get an extra life at 40,000 points.REVISION F (designed especially for novice players) :information First level has a colored background.information Default high-score is smaller than on Revision D : 25,600.information First nickname on the default high-score table is KAC.information Spinach is restored after you lose a life.information The ladder at the center of the first level can be used to go up or down.information Extra Life dip-switch can be set at 20,000, 30,000, 50,000, or None, with 20,000 as the default.BOOTLEG :information No copyright
First off, Hoopz is right.
There are a couple of roms for the bootleg versions. Maybe try playing one of those on MAME and see if anything different sticks out?
