Author Topic: My first CP layout attempt...  (Read 1292 times)
SoooPig
  • Last login:July 02, 2004, 07:40:06 pm
  • Wooohoo!
« on: December 18, 2003, 05:10:34 pm »
In the atwork forum, I posted my first attempt at my panel layout and associated artwork.  I'd appreciate any comments, that is, unless they are unkind ;D.
Warning... 250k picture attached to the thread...(for you low-bandwidthers)
http://www.arcadecontrols.org/yabbse/index.php?board=13;action=display;threadid=14323
TalkingOctopus
    • My Arcade
Re:My first CP layout attempt...
« Reply #1 on: December 19, 2003, 01:27:01 am »
I think your layout looks pretty good.  The best thing to do is make a cardboard mock up before actually constructing your final cp.
The only change I would make is that I would remove the 3 buttons next to the spiner.  I think that the top 3 player 1 or 2 buttons will suffice.  I would then put your spinner where those 3 buttons were.
What game is the 'G' button for?
Good luck
chrisindfw
  • Last login:May 09, 2020, 05:57:34 pm
  • I drank what?
« Reply #2 on: December 19, 2003, 09:02:25 am »
http://www.arcadecontrols.org/yabbse/index.php?board=13;action=display;threadid=14338
Here is my control panel. I would love to know what you guys think about it.
Please!
zaphod
  • Last login:September 04, 2012, 11:11:38 am
    • ArcadeCab.com
« Reply #3 on: December 19, 2003, 09:22:17 am »
I like the classic artwork.  Very nice.
I see a few things.
Pause and Exit are entirely too close together.  You'll end up quitting a game by accident.
Is 'Player 1' button the Coin Up or Player 1 Start?  If it is Coin Up, then I don't see a Player 2 Start, which is bad.
Are there 4-way games that require 4 buttons?   Or is that for other gaming systems?
From personal experience I would shift your 4-way joy a bit to the left.  It is going to get whacked during trackball use.
Just my opinions.   Looks like you're well on your way.
chrisindfw
  • I drank what?
« Reply #4 on: December 19, 2003, 09:27:56 am »
Thanks! I wanted something simple but not just a plain black control panel.
Honestly, I have no idea why I need 4 buttons for the 4 way. I have seen it on every other panel so I thought I'd do it too. :)
The two white buttons on each end are the Player 1 and 2 start buttons. To insert coins I will make the shift - start perhaps? Ultimatly I will make it where you have to press the coin reject button or insert a coin to make it work. (See if I can get some change from my friends !)
SoooPig
  • Wooohoo!
« Reply #5 on: December 19, 2003, 10:13:42 am »
Good luck
Thanks for the input.... I have the 3 buttons there to use them as mouse input buttons + 1 extra for missle command.  Using the existing buttons may be a way to go, I'll look into it.
I was waiting for the 'G' button question.  I'm a Track and Fieldaholic. The main purpose of the 'G' button is for the second Run button, but I'll program it for lefties that want to play Galaga... etc.
