Author Topic: Mala still active after emulator launch (Winuae)  (Read 3657 times)
XTrek
  • Last login:August 05, 2017, 06:54:51 pm
« on: December 08, 2014, 02:12:12 am »
i Have Winuae set up with hardisks and games (amiga desktop) so i want Mala only to start Winuae so that Winuae starts itself loading up the Amiga Desktop and then im using the amiga desktop to load games and other stuff. And i manage to start Winuae this way using a Bat file pointing to a Winuae Config file *.uae
In the rom path and have nothing as executable.
But Mala is still active in the backround even tough Winuae is runnig its desktop so when i press the joystick button again it loads up another instance of Winuae . and also if i push joystick left and right somehow the other Emulatos i have is visible for a second and then the emulated Amiga desktop appears again. Very strange.   I have set Winuae to run full screen and also Always on top option but somehow Mala doesnt know that Winuae is running. Other emulators i have setup with mala works normaly.
empardopo
  • Last login:November 17, 2025, 01:32:25 am
    • My personal forum
Re: Mala still active after emulator launch (Winuae)
« Reply #1 on: December 10, 2014, 01:40:30 am »
You could post some screenshots of your configuration.
empardopo
    • My personal forum
« Reply #2 on: December 11, 2014, 01:16:04 am »
A pair of links for you! Link1 Link2 (in spanish)
Greetings!
