Author Topic: Issue with rotating monitor and centering inside cabinet  (Read 1814 times)
lowlytech
  • Last login:February 07, 2019, 08:12:12 am
« on: November 16, 2014, 11:58:23 pm »
I have been working for the last year on and off on my first arcade cabinet and I wanted to make it as versatile as possible since it will be likely "the one and only".  I have been working on the rotating monitor and having a few issues with alignment. I have the HP2065 monitor.   I have it where in horizontal the monitor is lined up perfectly in the cabinet.  However when I rotate the monitor to vertical position the monitor is about 5/8 inch off to one side with respect to the cabinet shell.  I did notice the VESA mount on this particular monitor is about 1/2" lower from being in perfect center.  I didn't know if this was the issue or if anyone else had experienced centering issues when rotating their monitor.
Thanks for a great forum and community.  I look forward to any insight, and I am su :)re I will have more questions as I progress.. :)
Jakobud
  • Last login:November 18, 2025, 02:28:46 am
Re: Issue with rotating monitor and centering inside cabinet
« Reply #1 on: November 17, 2014, 01:23:55 am »
Simple solution, rotate it back to normal position, raise (or lower?) the monitor 5/8". Fixed.
lowlytech
« Reply #2 on: November 17, 2014, 08:50:43 am »
I guess I was thinking if I moved the monitor to the left in vertical position then rotated back to horizontal, then horizontal will not be centered.  I don't think there is a solution as much as I was wondering if anyone had ran into this issue before.  I think for the most part it will be in horizontal orientation for 70 percent of the time so I am focusing on that.
lowlytech
« Reply #3 on: November 17, 2014, 08:54:27 am »
Thanks for the input, I will try to lower or raise the monitor in horizontal and see how that affects the vertical position.
« Reply #4 on: November 17, 2014, 09:06:52 am »
you have inspired me to invent something, passing the idea over to Haruman now  :cheers:
TopJimmyCooks
« Reply #5 on: November 17, 2014, 09:07:07 am »
regardless of where the vesa mount holes are, the center of rotation has to be the center of the monitor display area.  you may need to make a plate to offset the VESA mount points to the center of rotation.
keilmillerjr
  • Web Developer.
« Reply #6 on: November 17, 2014, 09:49:39 am »
THIS ^^^^.
Take my rotary engine stand for example. Engine bracket attaches to front plate, which is rotated on the bottom when assembling so multiple plates can be stacked. The engine bracket is offset, so when the engine is complete, it will rotate on the stand towards the center of the engine. Same concept can be used for your rotating monitor.
  • Last login:Today at 01:02:43 am
« Reply #7 on: November 17, 2014, 10:02:40 am »
Yeah, making a offset plate you can bolt the monitor to should take care of things.
  • Last login:Today at 12:10:06 pm
« Reply #8 on: November 17, 2014, 10:44:27 am »
Only way to do it.
I made a template of the monitor out of foam board, then marked the center of the screen, then marked the VESA mount locations, then marked mounting points for my bearing (circled in red) based on the center of the screen.
http://forum.arcadecontrols.com/index.php/topic,119308.msg1270530.html#msg1270530
After all those points are marked, you have a template for your adapter plate.
Skip to :30 and watch the center  ;D
http://youtu.be/LQcVLFtxoUA?t=30s
« Last Edit: November 17, 2014, 10:48:50 am by BadMouth »
lowlytech
« Reply #9 on: November 17, 2014, 10:56:15 am »
awesome guys.  Thanks for all the info and the pictures.  Helps out this mechanically challenged brain of mine.
