Author Topic: How to achieve this curve?  (Read 4729 times)
GSXRMovistar
  • Last login:April 16, 2025, 06:01:17 pm
  • Gez, this is gonna be expensive!
    • forum.arcadecontrols.com/index.php/topic,148135.0.html
    • CoffeeCade
« on: November 04, 2014, 03:41:16 pm »
Hi there, I've mocked up a cabinet design in sketch-up I'm considering attempting and all seem straight forward for the exception of one curve. Below is a cross section view of where the controls will be mounted, the 'B' curve will be a chamfer using a router but I can't figure how best to create the 'A' curve. Any ideas?
Thanks. :)
« Last Edit: November 07, 2014, 04:31:17 pm by GSXRMovistar »
lamprey
Re: How to achieve this curve?
« Reply #1 on: November 05, 2014, 12:24:52 pm »
Did you forget your attachment?
GSXRMovistar
    • CoffeeCade
« Reply #2 on: November 07, 2014, 04:31:44 pm »
Oops!! Now added, thanks.
spoot
  • Destroyer of electronics
« Reply #3 on: November 07, 2014, 05:09:47 pm »
Sure you don't want to simply use a round over bit instead of a chamfer bit on B?
As for A....how about forming a strip to glue on afterward via router/table?  Or am I envisioning this from the wrong "angle"?
« Reply #4 on: November 07, 2014, 05:11:37 pm »
Thanks. :)
Lots of wood putty and sanding. Or see Spoot's suggestion.
spoot
« Reply #5 on: November 07, 2014, 05:15:26 pm »
Yeah, that's be easy too.  Could take a large dowel or some pvc pipe etc to wrap the sandpaper around to keep the curve consistant.
« Reply #6 on: November 07, 2014, 05:24:32 pm »
I would personally just bend sheet metal and have a metal CPO. If you don't mind a ridge, then just get some cove trim and be done.
liquid134
  • Last login:February 15, 2018, 07:58:20 pm
« Reply #7 on: November 08, 2014, 03:48:55 am »
x2 on the dowel rod/pvc pipe. just finding the correct diameter for what you want would take some trial and error
Louis Tully
« Reply #8 on: November 08, 2014, 04:44:59 am »
« Last Edit: February 12, 2015, 06:00:21 pm by Louis Tully »
EMDB
  • Project RetroCade
« Reply #9 on: November 10, 2014, 05:35:08 am »
This is what I did: Freehand routing and sanding afterwards to get the curve really smooth:
GSXRMovistar
    • CoffeeCade
« Reply #10 on: November 11, 2014, 05:31:55 pm »
But thats for the end pieces which are only 15-18mm wide, I'm wanting to apply a similar curve to a piece which is 660mm wide.
« Reply #11 on: November 11, 2014, 06:57:15 pm »
Yeah, I don't think EMDB understood like the rest of us did.
Honestly, I've only ever seen that piece curved on a metal panel. None of the wood ones I've ever seen have a curve like that.
EMDB
  • Project RetroCade
« Reply #12 on: November 13, 2014, 10:31:22 am »
I didn't indeed  ::)
