Author Topic: G27 for mame  (Read 7554 times)
jackiabu
  • Last login:May 18, 2025, 02:29:49 pm
    • http://jackiabu.blogspot.com/
G27 for mame
« on: October 07, 2014, 02:32:12 pm »
Hi
Today I bought a new steering wheel. I bought it because it was on sale ...
Anyway my current wheel is fine. FGT Rumble 3-in-1
My question is should I replace the old one with a new one? The G27 is well adapted to MAME?  or the Model 2 emu?
Most of the games I play on my Out Run machine is : Mame racing games like:outrun ,chase hq etc.  all so games like outrun 2006,need for speed etc.
the button line is what the benefit from the G27 to other wheel?
my new G27
my old and good wheel///
Re: G27 for mame
« Reply #1 on: October 07, 2014, 02:43:56 pm »
The G27 works well for most things.
Benefits:
More powerful ffb
Will shake for games that only have rumble (not real ffb)
Logitech Profiler software allows you to have custom settings for every game or emulator.  (most older games & demul emulator prefer the pedals be "marked combined"=on same axis)
Most newer games come already configured to work with it.
Drawbacks:
The clutch pedal shows up as the z-axis and can't be modified in the Logitech profiler software.  I have a few older games where this causes the menus to scroll unless you hold it down exactly halfway.  It also registers when trying to map controls in Demul unless you hold it down exactly halfway.
The main things would be the appearance and more powerful ffb.
It's up to you whether it's worth it to redo your cab for those things.
jackiabu
Re: G27 for mame
« Reply #2 on: October 07, 2014, 03:12:43 pm »
BadMouth Thank you for your quick response. ;D
What bothers me is what you say that" The clutch pedal shows up as the z-axis and can't be modified in the Logitech profiler software..." is it for mame? Or some  other racing games?
Re: G27 for mame
« Reply #3 on: October 07, 2014, 03:41:53 pm »
It doesn't affect MAME.
In Demul, when you try to map controls the Z-axis will register before you have a chance to press the button you intended to map.
Unless the pedal is held down halfway, Demul sees it as the Z-axis being held in one direction.
Think of it in terms of a gamepad.  The joysticks are centered when not being used.
Once you get the controls mapped, everything works fine.  You only have to deal with it once.
Just hold down the clutch halfway when mapping the other controls.
Edit:
I can't even remember the name of any of the old games I had an issue with.
I've never heard anyone else complain about it.
It irks me personally because I wanted to play the game FUEL which doesn't even support wheels.
I could get the wheel working using x360ce xbox controller emulator, but the game has the z axis hard coded which causes my vehicle to go backwards unless the clutch pedal is held halfway down.  It's a budget game nobody cares about, but I really enjoy driving around offroad in it.
« Last Edit: October 07, 2014, 03:50:32 pm by BadMouth »
jackiabu
Re: G27 for mame
« Reply #4 on: October 07, 2014, 03:55:30 pm »
Edit:
ok thanks you for that info. i see that my G27 came whit no Driver do i need Driver or some util? in the website i see nothing...
« Last Edit: October 07, 2014, 03:57:43 pm by jackiabu »
Re: G27 for mame
« Reply #5 on: October 07, 2014, 04:03:51 pm »
jackiabu
Re: G27 for mame
« Reply #6 on: October 07, 2014, 04:24:25 pm »
ok thanks men for your help ;D
Now I have a lot of work.
I will update later ...
MrThunderwing
  • Last login:January 17, 2026, 07:15:09 am
Re: G27 for mame
« Reply #7 on: October 07, 2014, 07:03:57 pm »
I've got an FGT 3-in-1 also. It's such a great budget priced wheel, I picked one up on a bit of a spur of the moment a couple of years ago for about £30 (which is about £12 less than a new PS3 dual shock 3 pad would've cost me at the time) and was amazed how good it was for how little it cost. I've only recently upgraded to a new wheel with proper working force feedback, which admittedly is better, but I still love my FGT 3-in-1.
When Setting up the FGT in MAME back in the day I had the issue of one of the axes registering before anything else showed up unless the pedal was held down halfway, but I think this may have only been when the wheel was in 'combined' mode rather than 'separate'.
jackiabu
Re: G27 for mame
« Reply #8 on: October 08, 2014, 09:25:52 am »
Well after I took apart the old panel of the machine.
I put the G27 and unfortunately Panal not fit the new steering wheel.
There is not enough room for gear shift.
Even palte of the accelerator pedal too much big or long :banghead:
I need a few things:
Build a new panel to fit the G27 wheel. The problem I need to do all that re-wiring again for the I-PAC etc.
Find a place to the shift  transmission. may build a special facility :badmood:
« Last Edit: October 08, 2014, 10:24:50 am by jackiabu »
