Author Topic: Priority in Gaming devices to a device USB in window 7 64bits  (Read 5078 times)
kanario40
  • Last login:August 28, 2025, 06:53:00 pm
I,m finishing my simulator of car but I have a problem.I have installed the game Outrun 2006 Coast 2 Coast.
I have two devices conected to usb,the steering wheel logitech and a hack of pad used to the buttoms.
If I have connected the two devices usb in that game always detected first the hack pad device instead of logitech usb.
Does anyone if exists any program that I can to use to give priority always to Logitech usb instead of hack of pad?
nugarp
  • Last login:February 22, 2026, 08:15:13 pm
Re: Priority in Gaming devices to a device USB in window 7 64bits
« Reply #1 on: August 28, 2014, 05:53:43 pm »
If you go to USB game controllers in the windows control panel, you should be able to click an "advanced settings" button at the bottom which will allow you to set a default primary device. Try that.
« Reply #2 on: August 28, 2014, 08:47:16 pm »
It's a problem with the game unfortunately.
If I can ever get fxt released that'll be the next issue I address.
kanario40
« Reply #3 on: August 29, 2014, 05:25:04 am »
Ok Thanks for the replies,then the only solution to play it would be to weld each buttom directly to each buttom of steering wheel of logitech and remove the hack of pad,wouldn,t? or exist any other solution to can to play.
« Last Edit: August 29, 2014, 05:36:34 am by kanario40 »
« Reply #4 on: August 29, 2014, 07:37:16 am »
That or hook things up to a keyboard encoder, yes.
« Reply #5 on: August 29, 2014, 09:10:23 am »
+ 1 on the keyboard encoder
On mine, the Start button posts ENTER, the Exit button posts ESC, and the view buttons post arrow keys.
This works to navigate the menus of every PC driving game that doesn't require a mouse.
I only had two games that required an autohotkey script to post different keys: Need For Speed Underground 2005 requires you to press Q to quit and Outrun C2C requires F2 to change the colors of the cars (IIRC).  The scripts just remap my radio button (not shown)
kanario40
« Reply #6 on: August 29, 2014, 11:45:38 am »
That of keyboard decoder what is it and how does it work? Any picture can you upload explaining it better.Thanks.
« Reply #7 on: August 29, 2014, 12:02:15 pm »
http://lmgtfy.com/?q=keyboard+encoder
kanario40
« Reply #8 on: August 29, 2014, 01:06:31 pm »
Yes Badmouth now I know it,s a keyboard decoder(ipac,interface usb etc..).
In true I have one in home ,a interface usb to two prayers like this:
But if I connect that keyboard decoder and remove the hack of pad ,window 7 will detect like a normal usb device like hack of pad and I,ll have the same problem for the game Outrun,haven,t?
« Reply #9 on: August 29, 2014, 01:28:57 pm »
No.  Keyboards and gamepads are considered different things.
The game will see the wheel as the only game controller and it will be device #1.
kanario40
« Reply #10 on: August 29, 2014, 02:22:50 pm »
Ok BadMouth I,ll test using that keyboard device instead of hack of pad and I,ll say if works fine or not.Thanks back.
« Reply #11 on: August 29, 2014, 08:09:52 pm »
Lol I don't think you are listening.  It DOES work.  Why would we recommend a route if we didn't know if it worked?
Keyboard encoders (not decoders, get your terminology right) are the default standard for all games.  Since the only input device a game developer knows for sure will be on a pc is a keyboard, all games have some level of keyboard support and most have pretty good keyboard support.  You'll often run into an issue of hard-coded keys, but other than that....
Also use your head there for a second... you keyboard was plugged in when you used the gamepad right?  The gamepad, buy itself worked just fine right?  Yeah there you go.
kanario40
« Reply #12 on: August 30, 2014, 11:59:10 am »
Well today I have tested using an interface usb and works perfectly.It detects first the Logitech device and after the interface usb.
I believed that a hack of pad was detected to window of the same way that a interface usb but I was mistaken.
Thank so much to both for the replys.
