Author Topic: Start app from joystick button or key  (Read 3477 times)
theelf
  • Last login:June 12, 2016, 06:33:54 pm
« on: August 21, 2014, 08:18:37 pm »
Hi!!
I have xbmc installed on the computer
Is possible to assign a key or a joystick button, to start xbmc?  i dont want to do a emulator+list, because i just need to open xbmc
any ideas?
Skinnysloth
  • Last login:May 08, 2016, 08:38:26 pm
Re: Start app from joystick button or key
« Reply #1 on: August 21, 2014, 09:52:48 pm »
Is there any particular reason you don't want xbmc to open on startup of the computer?
If you're running windows, you can use the free program AutoHotkey to assign a joystick button or combination of buttons to open xbmc.
You'll need to have AutoHotkey load when the computer starts and edit the script.  More info here: http://www.autohotkey.com/docs/Tutorial.htm and http://www.autohotkey.com/docs/misc/RemapJoystick.htm
For example, a AutoHotkey script of:
Joy10 & Joy11::Run mspaint
will open paint when joystick button 10 and 11 are pressed at the same time.  If you replace "mspaint" with the executable file for xbmc, which I will assume is "xbmc" then the script should open xbmc when button 10 and 11 are pressed.  You can pick whatever button or combination of buttons to use.
empardopo
  • Last login:January 18, 2026, 03:32:00 am
    • My personal forum
« Reply #2 on: August 27, 2014, 01:14:08 am »
AllInOneFYC can be your friend! :-)
