Author Topic: Please help me figure this problem out with visual pinball 9.9 (solved)  (Read 7760 times)
jaharr01
 I am running VP 9.9 on my pin cabinet build. I have visual pinball working with full screen and b2s tables. the problem is I can only get 1020 by 764 windowed full screen resolution to work and fill the screen. I have a new fast computer that should run VP at a lot higher resolution. Can I manually change the resolution to 1920 x 1080 ? Would I have to change setting for each table or change it for all tables? On the screen res doc where you set up b2s, does this change the screen resolution. I can set resolution to 1920 x 1080 on older versions of visual pinball without a hitch.I posted this a few days ago on vpforums but I haven't got much help.There are some really smart people that use this forum and I was hoping you guys could help.
« Last Edit: November 24, 2014, 09:28:55 pm by jaharr01 »
  • Last login:Today at 05:00:16 pm
Re: Please help me figure this problem out with visual pinball 9.9
« Reply #1 on: August 14, 2014, 11:25:44 pm »
What front end are you using?  (Hyperpin, PinballX, etc.)
jaharr01
« Reply #2 on: August 15, 2014, 03:45:26 am »
I'm running pinballx, but it did it before I installed pinballx. The screen shot from below is from my desktop This machine is a windows 7 machine. My cabinet is a windows 8 machine, which makes me think it is a windows  8 issue
kixfan
  • Last login:May 22, 2018, 06:59:26 pm
« Reply #3 on: August 19, 2014, 09:47:21 pm »
You are launching from the play field monitor, right?
It was my understanding that it only shows the available resolutions from windows.   So, what resolutions show in your windows display settings?
jaharr01
« Reply #4 on: August 22, 2014, 03:51:09 pm »
ok it's weird it will work if I start pinballx and change the resolution while in pinballx the next time i start vp+pinballx it is fine
jaharr01
« Reply #5 on: August 29, 2014, 04:12:08 pm »
btw the problem was I updated the nvidia drivers. rolled them back and it is fine
jaharr01
Re: Please help me figure this problem out with visual pinball 9.9 (solved)
« Reply #6 on: October 24, 2014, 07:43:31 pm »
Problem fixed with earlier drivers
