Author Topic: Raspberry Pi Barstick (red and black) ...control panel assembly  (Read 9747 times)
VoltaTom
  • Last login:November 11, 2018, 09:42:10 pm
After a delay/failed attempt on my bartop cabinet, I decided to start smaller. My woodworking skills are poor :dunno
This is my first serious attempt at having a finished arcade... it will get done. *hopes*
My plan is based of Degenatrons 'Barstick' design:
Design plan:
  • Barstick with HDMI, USB x2, DC power jack, and power switch on back.
  • 2 player CP with 6 buttons each, 2 player buttons, 1 coin, 1 pause
  • Red and black theme (with some white)
  • Raspberry Pi as guts (RetroPie I thinking)
Sorry for the poor lighting/cell phone pics - I only made the workbench itself days before I started this project. 7ft of led strip lights are above the bench now.
« Last Edit: August 14, 2014, 10:20:47 pm by VoltaTom »
VoltaTom
Re: Raspberry Pi Barstick (red and black)
« Reply #1 on: July 30, 2014, 07:53:54 pm »
Picked a black for my cabinet. I'm going with flat black over the glossy black.
Cut holes for players on CP. Only holes left are 2 player buttons, coin, and pause (pause on top, other 3 on front). I need to line those up right not to hit anything inside.
Questions time. Think adding a button top centre on the CP is too close to PL1's buttons?
« Last Edit: July 30, 2014, 08:02:33 pm by VoltaTom »
Slippyblade
« Reply #2 on: July 30, 2014, 07:56:26 pm »
Following.  :)
VoltaTom
« Reply #3 on: July 30, 2014, 08:01:37 pm »
Following.  :)
*looks behind him* Ahh!
Any suggestions people have are welcome!
« Last Edit: July 30, 2014, 08:04:38 pm by VoltaTom »
Slippyblade
« Reply #4 on: July 30, 2014, 08:08:33 pm »
I'm curious how well these actually work.  They seem like they'd be a little on the lightweight side and would shift around during head-to-head gaming.  Looking forward to see yours.
Speed Racer
  • Last login:March 14, 2018, 11:06:09 pm
« Reply #5 on: July 30, 2014, 08:44:37 pm »
I'm keen to see how this turns out. Looks good so far  :)
I agree - the extra button would probably be a bit close to P1's buttons. Also, your control panel will have a nice, simple and clean look if keep it to a minimum. Player buttons and joysticks on top, with the coin and start buttons on the front sounds good.
That said, if you felt compelled to have a pause button (it can be quite handy!) make sure it is clearly not part of P1's controls.
VoltaTom
« Reply #6 on: July 30, 2014, 11:04:35 pm »
I forgot about that actually. I do have some rubber feet for this but I just can't seem to find them right now......
I kind of like the idea of keeping it minimal. While I would like a pause button, I'm not sure about the spacing still. It would be a different colour not to look like the controls. Thinking I will just ditch it now and use a shifted key for pause. Thanks.
VoltaTom
« Reply #7 on: July 30, 2014, 11:11:18 pm »
Items for back of cabinet. Going to paint the white wall plate black to blend in better. The DC plug will fit in the coaxial hole (with some adjustment) and there is room on the other side of the HDMI port for the switch. USB ports will go near the plate.
Fiddling around with some red and black marquee artwork. Working on a title still - I think I want something more exciting than "Tom's Arcade"
solar
  • Last login:August 26, 2018, 05:59:28 pm
Re: Raspberry Pi Barstick (red and black) ...painting stage
« Reply #8 on: August 05, 2014, 11:25:42 am »
For pause etc could you not use a button combo "P1 start + P1 Button 1" etc ? I'm not familiar with the pi software but i'd assume there will be the option to let you do that.  :)
Failing that a button hidden around the back would keep the front clean.
  • Last login:Yesterday at 07:42:11 pm
« Reply #9 on: August 05, 2014, 11:51:22 am »
Looks like that is his plan.   ;D
solar
« Reply #10 on: August 05, 2014, 12:18:34 pm »
Yeah i even read those posts a few times and was surprised it wasn't mentioned...how i missed the last sentence, i can't not see it now lol.
Ah well its still a good idea haha.
VoltaTom
Re: Raspberry Pi Barstick (red and black) ...control panel assembly
« Reply #11 on: August 14, 2014, 10:42:00 pm »
Finished painting! So glad that is done with.
Back panel is drying, then the cabinet is ready for assembly.
I decided to put together the control panel in the meantime. I was dreading this step because I KNEW there was going to be problems. As you can see in the 2nd photo, the one joystick was extremely close to my hardware. Just a very minor adjustment, and it worked.
As I expected, one of the front panel buttons hits the other buttons. I am thinking of various solutions but thought I'd ask the experts here to see what has been done in the past to solve this. Any suggestions? Or easy fixes? Getting different buttons isn't really an option.
« Last Edit: August 14, 2014, 10:44:15 pm by VoltaTom »
VoltaTom
« Reply #12 on: August 14, 2014, 10:51:16 pm »
Here is a draft of the artwork. Tried a bunch of backgrounds but this one seems good. Black bars are for the marquee braces - they won't be printed.
I'm not at all convinced on the name of Retro Piecade. Only chose it because of the software on the Raspberry Pi I'm using (Retro Pie).
Other names could be:
Raspicade (pronounced Ras-Pie-Cade not Raspy-cade)
Picade (again, Pie-cade not pee-cade ;D)
Suggestions? Thoughts?
« Last Edit: August 14, 2014, 11:20:00 pm by VoltaTom »
ed12
« Reply #13 on: August 14, 2014, 11:15:40 pm »
a leaf sitch..same  shell :size:..but a leaf instead
they come in a wack of dif config's..
ed
eds1275
  • Last login:March 11, 2026, 11:07:08 am
  • Rock and Roll!
« Reply #14 on: August 15, 2014, 01:59:20 am »
Can you not turn the one switch that is in the way? If it's close, you can try to find a giant washer and have the front buttons protrude a bit for little money. You could make a big washer out of wood or plastic if you can't find one the right size. Leaf switches are a good way to go as ed suggested.
As for the name, I think nameless is better than anything you have suggested. I always thought people putting MAME or Cade on their machines was akin to the Batcave, where everything is labelled unnecessarily. Not being mean, that is just my opinion and as a complete stranger from the internet feel free to ignore it. It seems like you are trying to force it.
VoltaTom
« Reply #15 on: August 16, 2014, 08:16:59 am »
ed
The one's from Ultimarc? Those would be perfect for this... Unfortunately I can't buy more buttons. Being in Canada has it's shipping limitations. $2 buttons + $18 shipping isn't worth it, unless there is an ebay supplier (free/cheap shipping). Next time I will using those for sure.
I might try the washer idea. I was at the hardware store looking for 1 1/4" PVC pipe to use - couldn't find any though. Wish I had ordered some of those leaf buttons in the planning stage.
Lol @ the batcave reference! Fair enough, and I tend to agree. I was trying to avoid " Tom's Arcade " but looks like that's what I'm down to next. Still working on this. Thanks for your input.
yamatetsu
  • Last login:Yesterday at 01:56:42 pm
  • Just because.
« Reply #16 on: August 16, 2014, 08:42:29 am »
Couldn't you simply turn the offending red button to the left, like Eds suggested ? Judging from the photo, that should do the trick.
VoltaTom
« Reply #17 on: August 16, 2014, 09:07:24 am »
I really should have put the microswtich on it. It ads a little bit to the length - just enough to make it annoying.
I did use this method. Jiggled around with it and got it to fit (kind of). P2 button was completely sideways...
Jammed it a little more and I'd say this is close enough. P2 button is slanted but it's good enough for me. It's not perfect, but neither is this cab!
Thanks guys. Time to wire up the CP. Now to place the iPac...
jmike
« Reply #18 on: August 20, 2014, 10:46:20 am »
You could take out the center of the button and flip it over.
(Just 2 tabs to push in and the center of the button comes out, then just flip it over)
Can't wait for the software part. I actually have one of those Raspbeery Pi things laying around.
nordemoniac
  • Weee! Hahaha...
« Reply #19 on: October 02, 2014, 07:29:33 am »
How's your project coming up?
I would, as suggested here, remove the button center and turn it 180 degrees. Bend/cut the micro switch connectors, and solder a couple of wires to it. That way you'll be able to insert the button with the player straight... It's pretty simple, the button is only three parts: cylinder, spring, button (+microswitch).
