Author Topic: Convert Mouse Click to Keypress  (Read 1548 times)
bimm25e
  • Last login:July 30, 2024, 08:44:11 am
« on: July 02, 2014, 07:00:04 pm »
I am running Hyperspin on a win XP machine and I have a trackball encoder that works just like a mouse in the control panel.  I need to use mouse 2 as the number 1 and mouse 3 as the number 2, this works great in notepad using a program called "x mouse button control", but it doent work so well in hyperspin or emulators (besides MAME, which lets me use clicks) .  Does anyone know of a way to ensure x mouse button control operates at a low enough level that keystrokes are sent to hyperspin successfully, or a different application that is a better fit?  thanks!
-andy
Re: Convert Mouse Click to Keypress
« Reply #1 on: July 02, 2014, 08:33:51 pm »
Try autohotkey,  but honestly there isn't such a thing as "low level" keypress simulation without the aid of some hardware.
bimm25e
« Reply #2 on: July 02, 2014, 09:46:30 pm »
I don't mean like hardware driven low-level obviously but one that takes a higher system priority than HyperLaunch low-level... either way....
nailed it! super roundabout but.... using ppjoy I created a virtual joystick that was looking at mouse inputs, then mapped clicks as joystick buttons in xpadder!
 Careful if youre using fusion the right click opens a menu  but.... set mouse right click to your HS exit key instead of a player button and completely avoid the issue!!!!
« Reply #3 on: July 02, 2014, 10:51:05 pm »
autohotkey
rbutton::1
Just that simple.
Much more direct than using multiple programs.
empardopo
  • Last login:January 18, 2026, 03:32:00 am
    • My personal forum
« Reply #4 on: July 03, 2014, 01:35:39 am »
You can learn Autohotkey or you can take a look to my program AllInOneFYC.
Greetings!
« Reply #5 on: July 05, 2014, 06:52:27 pm »
rbutton::1
This. You can easily set it using Hyperlaunch HQ. during setup, it asks you press the old key and new key.
D
