Author Topic: Does this exist - 4 way rotary Joystick  (Read 3047 times)
bimm25e
  • Last login:July 30, 2024, 08:44:11 am
« on: June 30, 2014, 12:33:32 pm »
So I'm looking at setting up a vertical digdug cabinet for MAME and I want to cover 4 way games AND spinner games...
is there a good option for a 4 way / spinner joystick?  I'd like to keep the control panel looking as stock as possible and dont think there is room on the side to squeeze in a dedicated spinner
Re: Does this exist - 4 way rotary Joystick
« Reply #1 on: June 30, 2014, 12:53:47 pm »
No.
  • Last login:November 13, 2025, 01:36:49 am
« Reply #2 on: June 30, 2014, 01:02:20 pm »
I don't think you could turn a rotary stick smoothly for the precision needed for some spinner games.  :dunno
  • Online Online
  • Last login:Today at 11:40:33 am
« Reply #3 on: June 30, 2014, 01:03:16 pm »
That's a real reach.   :dunno
Good luck with finding a 4-way stick that will turn smoothly enough to work decently as a spinner knob.   :dizzy:
IF you find one and IF you have enough depth under the panel, you might be able to couple the joystick to the spinner using a shaft coupler.
You may also be able to fabricate an arm and post setup like the one that keeps the body of the rotary switch from turning freely on a Happ Rotary Joystick. (P/Ns 96-1011-00 and 95-2507-00 below)
EDIT: On second thought, you might be able to adjust the microswitch arms or shave down the actuator (96-1012-00 -- only $2 here from Happ) on the Happ Optical Rotary stick to make it into a 4-way stick.
Anyone know if the Happ Optical Stick has clicks or if it turns smoothly? Confirmed as smooth turning here.
(IIRC the Loop-24 optical rotary stick has clicks)
EDIT2: Instead of bending switch arms or shaving the actuator, you might be able to cut off the 8-way end on the Rotary stick actuator and do the same on a Happ Super 4-way/8-way actuator so you can use the 4-way end of the Happ Super actuator on the Rotary.
Confirmed the same diameter shaft on both sticks. (The Rotary is basically a modded Super.)
« Last Edit: July 05, 2014, 06:19:47 pm by PL1 »
lamprey
« Reply #4 on: June 30, 2014, 05:09:07 pm »
The optical rotary might work. If it did you can get a 4-way joystick and use the base/restrictor plate from that on the optical. the happ rotaries use a pretty standard form factor.
How much space do you have to work with? A spinner only need take up as much space as a button
« Last Edit: June 30, 2014, 05:10:57 pm by lamprey »
  • Last login:Today at 09:37:55 am
« Reply #5 on: June 30, 2014, 05:14:48 pm »
Hot glue a piece of round paper with a pattern on it to the bottom of the joystick.  Stick an optical mouse underneath it and point it at the paper.  Done.
paigeoliver
  • Awesome face!
« Reply #6 on: June 30, 2014, 07:13:42 pm »
Looks like you are trying to solve a problem that isn't there. There sits the most space eatingest spinner in my parts building on top of a stock dig dug panel and it fits.
If it was me though I would install it so it comes up through one of the button holes for the pump buttons.
You can technically put together a Wico 4-way that is also a 12 position rotary stick, but it would be completely useless. Even the optical rotary sticks aren't really useful for spinner games, just for that one game that used them.
« Last Edit: June 30, 2014, 07:16:05 pm by paigeoliver »
bimm25e
« Reply #7 on: June 30, 2014, 07:40:51 pm »
unghhhh its soooo ugly..
Yeah Im finding  that the upper tier spinners are abut button sized, I think the spinner in the left button hole would be an excellent choice.
can anyone recommend a good button sized mounting spinner less than $50?
« Last Edit: June 30, 2014, 08:29:02 pm by bimm25e »
  • Online Online
« Reply #8 on: July 01, 2014, 04:17:20 am »
Good or cheap.  Pick one.   :lol
Seriously, just get the TT2 from GGG.
« Reply #9 on: July 01, 2014, 09:13:35 am »
I paid like $10-15 shipped for an Arkanoid spinner and hacked a mouse to it.  It's awesome for the three spinner games that are actually fun.
lamprey
« Reply #10 on: July 01, 2014, 12:53:43 pm »
+1. Plug and play!
