Author Topic: Dynamic list of games ?  (Read 5324 times)
jimmer
« on: June 24, 2014, 05:45:43 am »
I used ROMlister to create a list of 4way games (about 4000), and saved it as a MaLa gamelist.
Then in Mala configuration I checked 'Only collect games with ROM found in ROM folders'.
I was expecting my menu to show me just the 20 or so ROMs I have in my ROM folder, but it still shows all 4000 odd.
Am I missing something?  Like what collection is/does ?
Re: Dynamic list of games ?
« Reply #1 on: June 24, 2014, 01:51:44 pm »
The "Only collect games with rom found in rom folder" is an option for when MALA builds your all games list.
It has no effect on other lists, let alone a list made by another program.
You'll also have to refresh the main gamelist after changing the option.
Of course, that will undo anything you did in romlister.
« Last Edit: June 24, 2014, 01:53:48 pm by BadMouth »
« Reply #2 on: June 24, 2014, 06:36:28 pm »
You need to have romlister bounce its query against what's in your rom folder.  I can't recall if romlister ever got the patch for .7z or not but if not you can just do a batch rename and then back after you're done with romlister.  Then in MALA editor you can tweak the lists.  I find that works out pretty well.
jimmer
« Reply #3 on: June 25, 2014, 01:37:10 pm »
Thanks.
So it almost has the functionality I want.
I'd better put in a feature request. Something like this:
Option to only list games found in the ROM folder.
When checked, Mala will build and work from a second file for each gamelist it finds on the MaLaTree.
thanks, I hadn't spotted that option.
Rom lister is a better solution than I had before.  Can ROMlister be run via a batch command ? eg so I could run it with 4 diiferent searches to create 4 different gamelist when I change my ROMs ?
NOP
  • Last login:September 19, 2017, 08:22:27 pm
  • I stole my avatar.
    • winterMAME
« Reply #4 on: June 28, 2014, 09:01:09 am »
I pointed that to you here: http://forum.arcadecontrols.com/index.php/topic,139753.msg1447125.html#msg1447125
RL used to be a command line program only that could be batched, but people then complained it was too difficult to use so I built the GUI around it. heh.
Your best bet is after making each search just copy-n-paste the stuff in the -find: window to a text document.  then when you change your roms (how often do you expect to do such a thing?  I went over 6 years on my last upgrade) you can drop those -find: searches into the box and just hit go.  Not perfect, but no tool ever is for every user.
« Reply #5 on: June 28, 2014, 09:04:38 am »
Maybe he just thanked the guy that posted it first.  ;)
jimmer
« Reply #6 on: June 29, 2014, 05:38:34 am »
Thanks NOP.  I would have thanked you you too but I haven't been back to the software forum.
