Author Topic: William coindoor repaint  (Read 1085 times)
jibmums
  • Last login:June 24, 2018, 01:08:16 am
« on: June 02, 2014, 09:15:04 pm »
I'm restoring a Williams coindoor and am going to try repainting it using Brian Kelly's method seen in the video below: flat or semi-flat black spray paint first, followed with spattering of gloss black paint, to replicate the original look.  If anyone here has ever tried this method, I would like to hear any tips you may have, including what brand/type of spray paint used, as well as photos of the finished coindoor.  thanks guys.
« Last Edit: June 02, 2014, 09:17:37 pm by jibmums »
ed12
Re: William coindoor repaint
« Reply #1 on: June 02, 2014, 09:32:37 pm »
as a rule i clean the door,light sand very light,clean
then i use hammer black,comes out looking like factory orignal
no primer is nessary
ed
Ken Layton
  • Guru
  • Technician
« Reply #2 on: June 02, 2014, 11:20:18 pm »
Hammered black is the paint I use on coin doors.
jibmums
« Reply #3 on: June 03, 2014, 12:54:16 am »
Hammertone is correct for some doors, like early 80's Taito Stratovox and such, but not this one.
  • Last login:November 19, 2025, 06:13:57 pm
« Reply #4 on: June 03, 2014, 03:16:49 am »
^^^ What they said. Hammered paint. Easy and looks real good.
I don't think Ive ever seen a door without the hammered look, but I am definitely no expert.
« Last Edit: June 03, 2014, 03:20:27 am by DaOld Man »
« Reply #5 on: June 03, 2014, 12:10:54 pm »
+1 on Hammered Black.  You don't even need primer since it's Rustoleum brand.  Just make sure you sand everything down.  I've had the best experience when sanding it down to the metal or the old paint will tend to flake off.
D
