Author Topic: Controls interface options  (Read 1038 times)
JeffB13
  • Last login:July 02, 2017, 01:42:01 am
« on: May 06, 2014, 06:03:32 pm »
Hello, I am starting a cocktail build and am getting a little lost in all the options for controls interfaces.  The plan is to have a 3 sided table.  The long side will have two 8-way joysticks with 6 buttons each, plus 1P and 2P buttons.  One short side will have a 4/8-way switchable joystick, 3 buttons, 1P and 2P buttons, spinner and Tron joystick.  Other short side will have a 4/8-way switchable joystick, 3 buttons, 1P and 2P buttons and trackball.  Plus a few admin buttons somewhere.
So that makes a total of 5 joysticks, 28-30 buttons, spinner and trackball.  I was thinking I could double map some of the joysticks and buttons.  I don't anticipate using the long side and short sides at the same time.
I don't plan on using LEDs now, but may in the future.
I'm thinking if I double up I could get a way with the I-PAC Ultimate or maybe the Howler.  What other options are there for my setup?
Jeff
  • Last login:Yesterday at 01:26:35 am
Re: Controls interface options
« Reply #1 on: May 06, 2014, 06:16:19 pm »
Are you planning to put a full-size Tron joystick on a cocktail panel? On the short side?
JeffB13
« Reply #2 on: May 06, 2014, 06:32:50 pm »
Yes.  It will be a custom cocktail with a control panel the full width of the small side which will be 22".  I have yet to draw it out, but the plan is a 4/8 joystick on the left, spinner in the middle and Tron stick on the right with 3 buttons below the spinner.
