Author Topic: how to wire this button  (Read 2862 times)
Caparo8bit
  • Last login:April 28, 2018, 02:13:32 am
  • Hyperspin/Maximus
« on: May 02, 2014, 07:20:26 pm »
I just purchased this LED button to control power on pc (desktop) can you guys guide me in how to wire this up and also when I press the button  stays down so when I press again will come up is this good for controling power. Thanks
Sorry for my bad english  :blah:
« Last Edit: May 02, 2014, 07:29:44 pm by Caparo8bit »
Slippyblade
Re: how to wire this button
« Reply #1 on: May 02, 2014, 07:22:34 pm »
Nice button, where'd you get it and how much?
Caparo8bit
  • Hyperspin/Maximus
brad808
« Reply #3 on: May 02, 2014, 08:07:57 pm »
Use a multimeter set on continuity (either beep or ohms) put it on two of the connectors and push the bottom. There are only a few different combinations of two that it could possibly be. One of the connectors is probably common, one is probably for continuity when the button is depressed and the other is when the button is released.
Edit: Just saw what you're using it for (didn't read well), it's not best suited for that. If you are looking to replace a standard pc power on switch you want something that's momentary and comes back up immediately.
CHRIS-F
  • Last login:October 17, 2025, 12:26:28 pm
  • I always have screws left over after repairs :-)
« Reply #4 on: May 04, 2014, 11:15:32 am »
Hi,
I'm no expert, but if you like that button and want to use it you can sometimes carefully take them apart and remove the little locking pin what makes it lock into place, I have done it before on some buttons, others are moulded and you can't open them, just carefully try to open it and see if you can find the pin if you are able to remove it, the button will work then as a momentary push to make switch, just check continuity then as already suggested by other members with a multi meter to find the right pins.
Regards,
Chris.
MK3FAN
« Reply #5 on: May 05, 2014, 11:43:11 pm »
This should give you an idea. The "on/off" can be flipped to make it work how you want it to but the important thing is the common wire is in the middle and the other wire goes to either the "on" connection or the "off" connection...BUT...you need to use a meter to verify before hooking anything up. Think of it like pic #2. The common contact will slide over to either the "on" or the "off" position. When you press the switch once, it slides over to the "on" contact. When you press it again, it slides over to the "off" contact. Make sense?
« Last Edit: May 05, 2014, 11:53:08 pm by MK3FAN »
Sarver Systems
  • Last login:October 07, 2020, 12:46:05 am
« Reply #6 on: May 08, 2014, 12:57:37 am »
Your "on" and "off" should be relabeled as "Normally Open" and "Normally Closed".
Caparo8bit
  • Hyperspin/Maximus
« Reply #7 on: May 08, 2014, 02:19:46 pm »
thanks all for your help. i was taking the button apart to remove the part that holds button down and ones i got it open all parts start falling down so now the only part that works is de LED  :banghead:
  • Last login:November 22, 2025, 08:32:45 pm
« Reply #8 on: May 08, 2014, 03:18:24 pm »
abispac
  • Last login:November 21, 2025, 11:24:52 pm
« Reply #9 on: May 11, 2014, 12:12:34 am »
 :banghead:
  • Last login:Today at 05:14:12 pm
« Reply #10 on: May 11, 2014, 08:19:42 am »
When you buy another one, make sure it is momentary contact, and not latched.
