Author Topic: Disable emulators  (Read 2530 times)
empardopo
  • Last login:November 17, 2025, 01:32:25 am
    • My personal forum
Disable emulators
« on: April 29, 2014, 02:13:16 am »
Hi.
Would it be possible in MALA to disable emulators?
I would like to have set up some emulators but for example it be able to disable one without delete it.
Is this possible?
bbmonster
  • Last login:January 03, 2017, 04:38:01 am
Re: Disable emulators
« Reply #1 on: May 02, 2014, 03:08:15 am »
I haven't seen an option, unless someone else more versed with Mala chimes in.
You could use navigation trees. Have one tree setup with a set of emulators and another tree setup with another set of emulators. Then just switch trees from the options window. Well just a thought, because I was planning on having a "kid" friendly tree and an "adults" tree. That way the kids can't accidently switch to a list from the control panel, with the tree, they would need to access the options window which is not accessible from my control panel.
