Author Topic: Discreet door catch  (Read 3869 times)
s_busby_uk
  • Last login:August 22, 2017, 02:28:51 pm
Discreet door catch
« on: April 27, 2014, 03:16:53 pm »
For the bottom accessible rear panel on my cab, I'd like a catch that means I can open the door by pushing it in so that it then pops out, with no signs from the outside that it's openable. Sort of like a secret hatch. I THINK the following is what I'm after:
http://www.hafele.co.uk/shop/p/twin-roller-catch-spring-loaded/79324/9402
...but obviously I can't test it online. Can anyone tell if it will do what I want without a handle, and if it's not what I'm after does anyone have an option they'd recommend?
  • Last login:Today at 01:53:38 am
Re: Discreet door catch
« Reply #1 on: April 27, 2014, 06:49:59 pm »
You may find it easier to align spring-loaded magnetic catches like this one or this one.
This type of catch also avoids the potential problem of snagging on the pointy assembly the other one has mounted on the door.
« Last Edit: April 27, 2014, 06:54:30 pm by PL1 »
s_busby_uk
« Reply #2 on: April 27, 2014, 06:56:24 pm »
Hmmm yeah you may be right. Was trying to avoid plastic but seeing as it's hidden anyway it's not really a big deal. Cheers.
keilmillerjr
  • Web Developer.
« Reply #3 on: April 29, 2014, 10:30:58 am »
Lots of people use them for kitchen and bathroom cabinets, and they will probably see more use than an access panel in your arcade machine. The good thing is that if one breaks, you can go back to Home Depot or lowes and get another one for a few dollars.
s_busby_uk
« Reply #4 on: April 29, 2014, 10:37:30 am »
I've realised that the problem with these is that they rely on your "door" being able to push past them, so to speak, so that when you want to push them close there's room for them to engage the push mechanism. Which is a problem for me because the doors currently rest flush against two pieces of timber!
So I might have to use a handle after all - unless anyone else has any ideas?
eds1275
  • Rock and Roll!
« Reply #5 on: April 29, 2014, 01:59:59 pm »
velcro
« Reply #6 on: April 29, 2014, 10:48:55 pm »
Route a finger pocket on the back of the door.
