Author Topic: CRTEmuDriver for Windows 7 test results  (Read 120401 times)
8BitMonk
Re: CRTEmuDriver for Windows 7 test results
« Reply #240 on: October 15, 2014, 12:09:14 am »
Ok seemed to run fine with those turned off, thanks. Must've just been the anycatalyst giving it a problem.
Calamity, did you  notice that 2560x496 is listed twice?
  • Last login:Today at 06:15:36 am
« Reply #241 on: October 15, 2014, 06:48:23 pm »
Yeah, I already fixed that in the updated files: http://geedorah.com/eiusdemmodi/forum/viewtopic.php?id=65
8BitMonk
« Reply #242 on: October 16, 2014, 10:48:39 am »
It's still duped in the ResList - super.txt file in that download.
2560 x 496 @ 60.000000 super
cools
  • Last login:August 19, 2025, 04:19:37 pm
  • Arcade Otaku Sysadmin
    • Arcade Otaku
« Reply #243 on: October 16, 2014, 11:43:40 am »
It's fixed in the driver download, just not in the separated VMMaker/OSD one.
« Reply #244 on: October 21, 2014, 11:46:15 am »
Thanks, I'll fix it.
blontic
  • Last login:December 21, 2020, 08:03:28 am
« Reply #245 on: October 25, 2014, 03:18:44 am »
Anybody having any issues with win7 and hyperspin? I am using super resolutions and I can load groovymame directly and games look great. But Hyperspin just doesn't start. If I remote to the PC it works so it does seem like a driver issue.
Sledge
  • Last login:August 02, 2025, 01:37:53 am
« Reply #246 on: October 25, 2014, 03:55:57 am »
Win7 and Hyperspin work fine for me..
lettuce
  • Make It So!
« Reply #247 on: October 25, 2014, 05:17:36 am »
Ok excuses my ignorance but why would you want a res that's 2560???
« Reply #248 on: October 25, 2014, 05:28:10 am »
How many custom video modes are listed by ArcadeOSD (or how many lines do you have inside Modeline.txt)?
« Reply #249 on: October 25, 2014, 06:03:59 am »
Because at such a high resolution you can do fractional stretching on the horizontal axis without any visible artifacts while keeping the vertical integer scaled.
adder
« Reply #250 on: October 25, 2014, 09:54:10 am »
Hi Lettuce, have a read of this lot linked below, some really good information here which helped me as i was quite lost with groovymame and related tools, but this lot below helps :)
http://geedorah.com/eiusdemmodi/forum/viewforum.php?id=1
adder
« Reply #251 on: October 25, 2014, 09:55:44 am »
Quote from: Calamity
....at such a high resolution you can do fractional stretching on the horizontal axis without any visible artifacts while keeping the vertical integer scaled.
Calamity, i was wondering regarding this scaling, does it make no difference in the 'quality' of this scaling depending on if you are using direct3d or directdraw?
lettuce
  • Make It So!
« Reply #252 on: October 25, 2014, 05:38:23 pm »
ah so its for 31hz monitors to achieve a 15khz resolution?
blontic
« Reply #253 on: October 25, 2014, 10:08:57 pm »
Hi Calamity,
I have 14 lines in my modeline.txt file. Groovymame is running correctly it's just Hyperspin doesn't even start. When I installed the GPU drivers I had to install the MS Visual C++ 2010 redist before it would work otherwise I would get errors. http://www.microsoft.com/en-us/download/details.aspx?id=26999
Hyperspin works if I RDP to the PC just not when ran locally.
The driver install said it only installed 1 driver but in Add/Remove programs I can see 3 (see attachment) Just wondering if it's correct.
I also added the following lines to the top of my ume.ini file. Not sure if that's correct
      resolution 2560x0
      cleanstretch 2
Thanks,
b
« Last Edit: October 25, 2014, 10:18:16 pm by blontic »
Sledge
« Reply #254 on: October 25, 2014, 10:14:30 pm »
Not at all...
If i understand it correctly (kind of)... it's just an ultrawide resolution but with the correct height.. and the picture we want is 'plonked' in the middle with the 'extra' horizontal lines stretching off the sides of the screen...
cools
    • Arcade Otaku
« Reply #255 on: October 26, 2014, 03:09:57 am »
I'm using directdraw here (Win 7) and there are no scaling artifacts.
lettuce
  • Make It So!
« Reply #256 on: October 26, 2014, 05:46:33 am »
Not at all...
Right ok, so what's the benefit of doing this then over having a normal 4:3 resolution?, I take it this is 100% safe to use on 15khz monitors then?
cools
    • Arcade Otaku
« Reply #257 on: October 26, 2014, 07:25:07 am »
The CRT_Emudriver benefit is you only need half a dozen resolutions in the registry. There's no significant benefit to this other than Windows 7 loading more quickly. There are some* (* I don't remember which) games that have black side borders when an exact width mode isn't available natively. On a super resolution setup these go full screen width.
Depending on your monitor, you may only need (once there's a GM bug fixed) 1 or 2 custom "super" resolutions in the registry to support every game in MAME.
However, on a *non* ATi supported card - provided you can create a custom "super" resolution (Intel and Nvidia drivers support this) you can get excellent GroovyMAME results without resolution switching by using cleanstretch 2 and this super res. You run Windows and GM in 2560x480@60, and a good percentage of games behave properly (bar some being too fast/too slow) - this also avoids the picture/sync collapse you get when moving from frontend to game and back.
lettuce
  • Make It So!
« Reply #258 on: October 26, 2014, 09:21:17 am »
Thanks Cools
When Claimity officially releases 0.155 ill start playing around with this on my new 15khz monitor, just need to decided weather Win 7 or XP x64 is best.
Did you ever get a satisfactory outcome when you were trying a 31khz monitor to play 15khz games back last year?
cools
    • Arcade Otaku
« Reply #259 on: October 26, 2014, 10:35:07 am »
Yes, it didn't require these but I'm using them anyway for the boot speed. The settings are all documented on the new forum.
Sledge
« Reply #260 on: October 28, 2014, 08:51:32 am »
So, if the drivers are installed, the 'super' resolutions are available in arcadeOSD, but mame gives an error of 'no suitable resolution could be found that meets your specs' etc..
Where would we look to fix it?
Gmame is being run as admin of course.. as far as i know the ini is correct..
« Reply #261 on: October 28, 2014, 05:31:53 pm »
Maybe in the logs? ;)
Sledge
« Reply #262 on: October 28, 2014, 08:03:18 pm »
Yep.. Waiting for him to send them to me, but was wondering if there was a common mistake made that would cause it..
Sledge
« Reply #263 on: October 29, 2014, 02:30:43 am »
Setting lock unsupported modes to zero fixed it..
Does that always have to be turned off?
premuto
  • Last login:August 03, 2017, 07:29:07 am
« Reply #264 on: October 29, 2014, 07:59:41 am »
test:
ati hd 4550 on port dvi
windows 7 ultimate x64
drivers and instalation all ok
hyperspin work fine, but groovymame dont start in hyperspin,
anyone have a optimize mame.ini with all changes (resolution 2560x0, cleanstrech 2, etc)?
blontic
« Reply #265 on: October 31, 2014, 10:21:26 pm »
Hi Calamity,
      resolution 2560x0
      cleanstretch 2
Thanks,
b
So i tested this again on a fresh build and it's the drivers that break Hyperspin. I install them and Hyperspin doesn't load. I remove them and use the Windows driver and it works. This is without even running VMMaker. If I run VMMaker it doesn't make a difference.
I don't get any errors when installing the drivers and it boots into test mode. Any ideas? I run the driver install as admin.
Sledge
« Reply #266 on: November 01, 2014, 12:55:04 am »
Tried a fresh install of hyperspin?
I was having issues once.. had to do a fresh install of HS for it to work again..
http://www.hyperspin-fe.com/forum/showthread.php?29481-How-to-install-HyperSpin
« Reply #267 on: November 01, 2014, 09:36:30 am »
Hi Blontic,
Try disabling Flash hardware acceleration as explained here: http://geedorah.com/eiusdemmodi/forum/viewtopic.php?pid=379#p379
blontic
« Reply #268 on: November 01, 2014, 08:10:32 pm »
Hi Blontic,
Thanks Calamity,
I installed Firefox and disabled hardware acceleration but it still doesn't make a difference. Hyperspin doesn't start at all. Youtube doesn't have much flash content so I just used this link instead http://helpx.adobe.com/flash-player.html#main_Find_Flash_Player_version_type_and_capabilities__Flash_developers_only_
This is the only error I see which is in my app event log
Activation context generation failed for "D:/HyperSpin/HyperSpin.exe".Error in manifest or policy file "D:/HyperSpin/HyperSpin.exe" on line 0. Invalid Xml syntax.
blontic
« Reply #270 on: November 01, 2014, 09:36:56 pm »
Check this, (the final post): https://social.technet.microsoft.com/Forums/windows/en-US/376f1310-94c4-43a4-8376-32a16c3e091b/error-in-manifest-or-policy-file-side-by-side-error-59?forum=w7itproperf
Thanks i'll take a look. I found I had to have MS Visual C++ 2010 redist installed otherwise I would get an error installing the driver. Could you tell me what versions I should have installed?
Thamiel
  • Last login:June 03, 2025, 05:28:11 am
« Reply #271 on: November 03, 2014, 05:09:26 am »
Having a go with a Windows 7 setup at the moment.
Setup:
* Windows 7 x64 Ultimate
* 4350 HD
* 31k Arcade Monitor (using lcd to setup atm)
Getting the msvcr100.dll error even after installing the c++ redist package. Installer says one of the 4 devices installed correctly, attempt to run VM before restarting and it dosn't find a compatible driver and dosn't update the registry. PC restarts in low res modes, have to get into safe mode to uninstall the driver. Tried AnyCatalyst 1 and still the same issue.
« Last Edit: November 03, 2014, 07:55:36 am by Thamiel »
Sledge
« Reply #272 on: November 03, 2014, 05:47:07 am »
Are you running all the programs/installers with admin rights?
Thamiel
« Reply #273 on: November 03, 2014, 06:09:59 am »
Thanks for the reply, yeah definitely installing/running everything with admin rights.
« Reply #274 on: November 03, 2014, 09:35:56 am »
Thamiel, just ignore the msvcr100.dll error. Only 1 device must get installed. If you run VMMaker before restart, you need to point to the proper \\.\DISPLAY#, which is not "1" until you restart... so run VMMaker, see the proper display number prompted in its window (e.g. \\.\DISPLAY7), then edit vmmaker.ini with it and re-run VMMaker. This way it will be able to point to the proper registry key and you'll get 31 kHz after restart. Since, then, restore the display number in vmmaker to the proper value.
cools
    • Arcade Otaku
« Reply #275 on: November 03, 2014, 04:53:54 pm »
Thamiel
« Reply #276 on: November 04, 2014, 12:43:41 am »
Gave it a go with a fresh install of Win7.
-Installed Win7
-Installed CRTEMU drivers as admin, .dll error occurs, driver not signed error occurs, installer says drivers installed correctly.
-Run VMMAKER as admin, 4 displays listed (display1, displayv1, displayv2, displayv3) only display1 listed as connected. VMMAKER cannot find a compatible driver so nothing is written to the registry. 20 modes generated from my super resolutions (same as cools ones, worked fine on my XP machine).
-Restart PC, black screen after Windows loading logo. Switched monitors to try and see whats going in, Windows is using a 240p resolution. Definitely not the standard 640x480 31k res from my ReslList.
This is the error I get at the end of the CRTEMU driver install: http://www.64k-tec.de/wordpress/wp-content/uploads/unsigned_driver.png
That wording, not the specific driver I linked to obviously. Is it possible my Windows 7 copy is quarantining the driver and that's why VMMAKER can't find it?
krick
  • Gotta have blue hair.
« Reply #277 on: November 04, 2014, 12:55:29 am »
@Thamiel
Here's the install instructions from the driver download page (currently down, but there is a link to a mirror site in my signature)...
When installing CRT Emudriver in Windows 7, some extra caution must be taken:
1.- Run the Setup program with ADMIN RIGHTS enabled.
2.- DO NOT restart the system when W7 prompts you to do so, let the Setup program finish, allow it to set TEST mode on.
3.- CRT Emudriver for W7 doesn't boot in 15 kHz automatically after restart. You need to manually enable a 15 kHz mode from Arcade OSD.
4.- Remind to always run VMMaker with ADMIN RIGHTS.
5.- Windows 7 does not support "magic" resolutions. Use "super" resolutions instead.
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
Thamiel
« Reply #278 on: November 04, 2014, 01:24:55 am »
@krick
Thanks mate, defintely done that a few times though.
UPDATE: Restarted the PC in safe mode to uninstall the drivers and have another crack, upon getting back into normal Windows (in test mode) it automatically installed a video driver and told me to restart. Restarted and checked the driver in device manager and it had automatically installed Calamitys' drivers...ran VMMAKER just to see what would happen, sure enough it found the catalyst driver correctly and generated a mode list from cools super resolutions. Just copying some roms across now to see if it's handling things correctly. Utterly bizarre chain of events...
UPDATE2: GM is picking the right resolutions! Also comparing between WinXP 64 and Win7 64 there's quite a performance boost. Ibara and Pink Sweets are running 100% constantly without the need for triple buffer.
« Last Edit: November 04, 2014, 02:20:05 am by Thamiel »
« Reply #279 on: November 04, 2014, 07:56:52 am »
Signature error? Are you using the latest package (the one you can get from Krick's mirror) or the "beta" package linked previously in this thread?
