Author Topic: Router Advice (( (SOLVED) ))  (Read 4539 times)
Caparo8bit
  • Last login:April 28, 2018, 02:13:32 am
  • Hyperspin/Maximus
« on: April 14, 2014, 07:12:45 pm »
Just wondering if any of you guys have any good reviews (results) using this Router  (Planing to use this for t molding slot and copy sides of cabinet).Also what size of drill bit do i need for t molding and buttons hole . THAnks.
http://www.homedepot.com/p/Ryobi-Fixed-Base-Router-R163K/203325690
Option 1 (Drill bits) http://www.ebay.com/itm/7-pc-2-Deep-Hole-Saw-Wood-Drill-Bit-Woodworking-Set-Manufacturers-Warranty-/351048308035?pt=LH_DefaultDomain_0&hash=item51bc1c1543
Option 2  http://www.homedepot.com/s/wood+drill+bits?NCNI-5
« Last Edit: April 25, 2014, 05:54:38 pm by Caparo8bit »
matt4949
Re: Router Advice
« Reply #1 on: April 14, 2014, 08:35:37 pm »
I love that Ryobi. Most of your cabinet building bits are specialized and have to be ordered. My slot cutter was about $20, Porter Cable 3/16. And don't forget a flush trim bit. Make sure you get one at least an inch cutting width. Also when you order make sure you get the same size arbor as your router (1/4 in). A 50 kit of common router bits is a great investment. You'll find yourself doing all kinds of stuff around the house with the router. I drill my button holes wit a hole saw. I haven't had any problems with plexiglass yet.
matt4949
Re: Router Advice
« Reply #2 on: April 14, 2014, 08:36:39 pm »
NO!!!!!! on the paddle bits
Caparo8bit
  • Hyperspin/Maximus
Re: Router Advice
« Reply #3 on: April 14, 2014, 08:44:45 pm »
Gonna try to find a kit. i dont have a good harware store near me . Have to buy Online (home depot or ebay) also the flush Trim bit is the one that you can use to make the sides of two pieces the same right and any special size for that one? Sorry if im asking stupid quetions i always use Mickey Mouse Tools to do my jobs . Jut want a easy life..
Caparo8bit
  • Hyperspin/Maximus
Re: Router Advice
« Reply #4 on: April 14, 2014, 10:25:23 pm »
Generic Eric
Re: Router Advice
« Reply #5 on: April 14, 2014, 11:04:01 pm »
Ok, some people have to learn the hard way.   Listen to matt.
Groovygamegear.com has the t molding bit.  It depends on the depth of you t molding I think.
My experience with the hole saw in mdf, even in plywood was it is necessary to make sure the dust is cleaned out so the glue doesn't gum up too much.
Lastly,  I've read the Forster bit is were it's at.  I have yet to invest in one.
  • Last login:Yesterday at 06:31:37 pm
Re: Router Advice
« Reply #6 on: April 15, 2014, 12:07:29 am »
You can find quality Forstners cheap on eBay. That's the way to do it.
Caparo8bit
  • Hyperspin/Maximus
Re: Router Advice
« Reply #7 on: April 17, 2014, 12:45:48 pm »
cant wait to paint my bartop......if i paint right now before making the t slots can paint get damage will using the router???? ' i neva used a router'
Re: Router Advice
« Reply #8 on: April 17, 2014, 12:50:40 pm »
It shouldn't, but it will get REALLY dusty/dirty and could stick to the paint. I'd do it BEFORE painting.
  • Last login:February 01, 2026, 05:25:13 pm
Re: Router Advice
« Reply #9 on: April 17, 2014, 02:11:33 pm »
The T-Molding slot cutter is selected according to the width of the part of the t-molding that goes into the slot.
T-molding.com, and I am sure other sites, show a drawing and tells what width the slot cutter needs to be for the t-molding you are using.
I always cut the slot with the router first, then stick cardboard (thickness of cardboard close to the width of the slot, but a little less, so it doesnt fit tight), in the slot before painting.
Before the paint dries, I slide the cardboard back and forth then remove it.
Cardboard keeps paint out of the slots.
Getting paint in the slots is a big PITA later when you insert the t-molding, and should be avoided at all costs.
Of course if you are using laminate and not paint, you would apply the laminate first, then cut the slot.
Caparo8bit
  • Hyperspin/Maximus
Re: Router Advice
« Reply #10 on: April 17, 2014, 10:35:44 pm »
Im gettig t-molding and slot bit cutter from groovygame
matt4949
Re: Router Advice
« Reply #11 on: April 18, 2014, 06:47:06 am »
When you order, ask them to send some samples of their inventory. That way you can play with different colors in the future and know exactly what  color you want to order.
Caparo8bit
  • Hyperspin/Maximus
Re: Router Advice
« Reply #12 on: April 24, 2014, 09:04:52 pm »
:soapbox:  i forgot...................................................................................................!
