March 19, 2026, 01:39:49 am
Is this rare?
compare it to the back...if the back is properly centered, it was printed off.if it's off on the back too, it was cut off center.off cuts are not a big deal, a discrepancy between the back and front, however, is.
Quote from: lilshawn on March 27, 2014, 01:19:38 pmcompare it to the back...if the back is properly centered, it was printed off.if it's off on the back too, it was cut off center.off cuts are not a big deal, a discrepancy between the back and front, however, is. the back is normal "centered"
Quote from: Caparo8bit on March 27, 2014, 05:35:15 pmQuote from: lilshawn on March 27, 2014, 01:19:38 pmcompare it to the back...if the back is properly centered, it was printed off.if it's off on the back too, it was cut off center.off cuts are not a big deal, a discrepancy between the back and front, however, is. the back is normal "centered"Take it to the corner gas station and ask them to hit it with a forgery pen, just to make sure you actually have legit money. Then use it to buy snacks.
