Author Topic: Mario Pedestal. Finished. Better video added showing turning accuracy with PiP.  (Read 130014 times)
thomas_surles
Re: Mario Pedestal. How about this? Welcome to Warp Zone!
« Reply #80 on: April 20, 2014, 12:32:26 pm »
How awesome would it be to drop a quarter in the pipe to add a credit
Louis Tully
« Reply #81 on: April 20, 2014, 12:55:21 pm »
« Last Edit: February 12, 2015, 04:46:59 pm by Louis Tully »
Louis Tully
« Reply #82 on: April 27, 2014, 02:19:33 pm »
« Last Edit: February 12, 2015, 04:47:08 pm by Louis Tully »
thomas_surles
« Reply #83 on: April 27, 2014, 11:11:32 pm »
How about a dark theme like the fan art I found.
« Reply #84 on: April 27, 2014, 11:55:18 pm »
I dunno, I still kind of prefer the first design.
Louis Tully
Mario Pedestal. How about this? 2 pipes
« Reply #85 on: April 28, 2014, 05:52:55 am »
« Last Edit: February 12, 2015, 04:47:23 pm by Louis Tully »
SpaceHedgehog
  • Last login:March 14, 2026, 10:40:09 am
  • Almost done ...
Re: Mario Pedestal. How about this? 2 pipes
« Reply #86 on: April 28, 2014, 06:23:15 am »
Don't know whether this is of any use (maybe for some ideas), but I built this using table legs and tubing for hiding cables:
Still have to complete a few bits on it.
Click a pic for a video tour
thomas_surles
« Reply #87 on: April 28, 2014, 09:12:38 am »
Im really digging the new 2 pipe design. I think shes the one.
  • Last login:Today at 07:04:36 pm
« Reply #88 on: April 28, 2014, 10:43:29 am »
Not so sure about having the whole front in brick.
How about doing the front like a standard SMB screen and the CP like a cloud level (not shown) screen?
Perhaps the lower 6-10 inches in a stone pattern, followed by bushes, mountains and sky with several levels of floating brick shelves with those pushbuttons positioned in the uppermost layer like the floating shelf in the screencap.
If you use SpaceHedgehog's monitor mount, consider wrapping the left monitor support with 3-D steps and have the flagpole as the right monitor support.
« Last Edit: April 28, 2014, 10:45:18 am by PL1 »
« Reply #89 on: April 28, 2014, 10:51:49 am »
Agreed. I like the original art design, but just add the second pipe.
jdbailey1206
« Reply #90 on: April 28, 2014, 12:08:52 pm »
Huh huh huh.  Second pipe.
« Reply #91 on: April 28, 2014, 12:15:07 pm »
too much brick.   keep the 2 pipes, and the row of bricks between the top of the pipes, do the rest with blue skies, clouds, bushes, and the "floor rocks"
Caparo8bit
  • Last login:April 28, 2018, 02:13:32 am
  • Hyperspin/Maximus
« Reply #92 on: April 28, 2014, 01:09:22 pm »
That is some nice artwork and I truly appreciate the suggestion. I'll keep that in mind when it's art time.  :cheers:
I like the first design more than the fireplace but I worry that it'd be unstable. How's this for a Yotsuya seal of approval? PL1 said 2 pipes a while back and so I gives it a shot.  :cheers:
Still as stable as the log burner, still has spots for the wheel mounts, and has the pipe support idea. Has a metric-$%#@ton of bricks but I don't care. Once I start, I'm all in. I'll round those corners on the control panel and base of course. This seems better. At least moving in a better direction.
Keep that critique coming.
front is missing some windows to make it look like a castle
Louis Tully
Mario Pedestal. How about this? 2 pipes and less bricks.
« Reply #93 on: April 28, 2014, 09:12:34 pm »
« Last Edit: February 12, 2015, 04:47:50 pm by Louis Tully »
Re: Mario Pedestal. How about this? 2 pipes and less bricks.
« Reply #94 on: April 28, 2014, 09:15:07 pm »
Is this what you guys are talking about? Not specifically this but something down this path. It like a better version of what I started with.  :lol  :banghead:
You went too far in the other direction, bro.
Louis Tully
« Reply #95 on: April 28, 2014, 09:18:17 pm »
« Last Edit: February 12, 2015, 05:07:21 pm by Louis Tully »
« Reply #96 on: April 28, 2014, 09:22:10 pm »
But with two pipes
« Reply #97 on: April 28, 2014, 10:02:38 pm »
Pardon the craptastic MS Paint hack, but this is a bit closer to what I was thinking.
« Reply #98 on: April 28, 2014, 10:15:33 pm »
1) Motorcycles kick ass.  Have fun.
2) I still like this one but do the following to "fun" it up
    a) change the bricks right below the pipe to the blue stone
    b) do the base in grey stone and lava
    c) do the area above the pipes but below the "ground level" CP as an underwater stage.
3) Disregard all of that, get a piece of gianourmous PVC, do it up to look like a pipe coming out of a brick ground, and put a cocktail machine inside it like barrel of kong
4) Profit.
« Reply #99 on: April 28, 2014, 10:31:02 pm »
I say put the horizon in the middle. Too much sky otherwise.
thomas_surles
« Reply #100 on: April 28, 2014, 10:38:20 pm »
Just a doodle on my phone of what I was thinking. Maybe a little too simple
« Reply #101 on: April 28, 2014, 11:23:02 pm »
Sounds good.
Maybe a mashup of an inset underground level (like the warp zone render) for the bottom half and an inset version of the above ground screenshot with a physical piece of pipe extending down from the upper level inset to the underground inset.
« Last Edit: April 28, 2014, 11:26:16 pm by PL1 »
Caparo8bit
  • Hyperspin/Maximus
« Reply #102 on: April 29, 2014, 12:26:46 am »
But with two pipes
hey that gif is Copyright your using my face......  :laugh2:
« Reply #103 on: April 29, 2014, 12:33:11 am »
Louis Tully
« Reply #104 on: April 29, 2014, 05:37:50 am »
« Last Edit: February 12, 2015, 04:48:23 pm by Louis Tully »
« Reply #105 on: April 29, 2014, 07:51:42 am »
same but I figured full brick between coin up question blocks.   However I really like the idea of the underground section too.
Louis Tully
« Reply #106 on: April 29, 2014, 08:00:32 am »
« Last Edit: February 12, 2015, 04:48:29 pm by Louis Tully »
JDFan
« Reply #107 on: April 29, 2014, 08:40:04 am »
Perhaps use the physical pipes with 90 degree connectors at the different levels and set the background back a bit for that 3d effect.  :dunno
« Reply #108 on: April 29, 2014, 08:50:39 am »
Something to consider for sideart.
Left side: Bridge level (2-3?) over an underwater level. (2-2?)
Right side: Platform/mushroom level (1-3/4-3?) over a lava level. (1-4?)
Handy list of levels and worlds available here.
Click on the desired world# and scroll down for level maps like the links above.
Just like in this earlier render.   :cheers:
DarakuTenshi
    • Card Fighters Project
« Reply #109 on: April 29, 2014, 09:04:51 am »
I'm with you on that. When I saw the original idea I actually got a little bit upset that I didn't come up with that design.
And this is more what I had in my mind after seeing the original idea as well. Now this is slick!
JDFan
« Reply #110 on: April 29, 2014, 09:12:41 am »
Yes but with insets for each level (ie. Underground, Water, Sky) and the pipes to the sides like in the other renders rather than 3 pipes in the one inset -- so that the insets are the various levels and tied together with the pipes he has at the sides.
Louis Tully
« Reply #111 on: April 29, 2014, 09:14:32 am »
« Last Edit: February 12, 2015, 04:48:48 pm by Louis Tully »
keilmillerjr
  • Web Developer.
« Reply #112 on: April 29, 2014, 05:45:36 pm »
---steaming pile of meadow muffin---, just make this thing out of real bricks and PVC. No artwork needed.  :cheers:
ChanceKJ
« Reply #113 on: April 29, 2014, 08:06:36 pm »
Can't imagine how fricken' heavy that would be. Might as well just use real metal pipe at the point and say to hell with the thin PVC.   :D
Louis Tully
« Reply #114 on: April 30, 2014, 03:25:03 am »
« Last Edit: February 12, 2015, 04:48:52 pm by Louis Tully »
Louis Tully
Mario Pedestal. 2 pipes and 3d front stuff. Cloud control panel.
« Reply #115 on: May 01, 2014, 08:27:35 pm »
« Last Edit: February 12, 2015, 04:48:58 pm by Louis Tully »
Re: Mario Pedestal. 2 pipes and 3d front stuff. Cloud control panel.
« Reply #116 on: May 02, 2014, 12:40:45 am »
Even if you don't build it, it's cool you're learning about Sketchup this way!
Louis Tully
« Last Edit: February 12, 2015, 04:49:06 pm by Louis Tully »
Louis Tully
Mario Pedestal. Another design. #8 by my count. No PVC version.
« Reply #118 on: May 10, 2014, 10:43:03 am »
« Last Edit: February 12, 2015, 04:49:18 pm by Louis Tully »
thomas_surles
Re: Mario Pedestal. Another design. #8 by my count. No PVC version.
« Reply #119 on: May 10, 2014, 02:53:18 pm »
What if you took this same concept and added 2 pipes on each side.like 2 on the left side and 2 on the right side
