Author Topic: how is your joystick mounted ?  (Read 3017 times)
shayvidas
  • Last login:March 28, 2016, 09:18:22 pm
  • mame Fan Forever !!!
« on: March 10, 2014, 08:14:32 pm »
i asked it before on the woodworking forum on how to mount a joystick,
and i did got good answers..
but i really want to mount my joystick as high as possible, and i don't have a router (only a jigsaw)
just a question on how is your joystick in your cabinent mounted ? to know what most are using...
mgb
  • North East, US
Re: how is your joystick mounted ?
« Reply #1 on: March 10, 2014, 08:53:39 pm »
you can try a seimitsu with an s plate mounted like this from underneith with a square cutout and then fill it or something and cover it with graphics and lexan.
best bet for having the stick sit as high as possible would be to go with a metal control panel.
  • Last login:Today at 04:10:26 pm
« Reply #2 on: March 10, 2014, 10:52:43 pm »
Get a longer joystick shaft.
« Reply #3 on: March 11, 2014, 12:34:01 am »
I use carriage bolts, but I also use metal control panels as well.
bradx
  • Last login:December 02, 2016, 02:39:53 am
« Reply #4 on: March 11, 2014, 03:07:16 am »
i use a circle drill bit for the center hole and mount it with wood screws.  my wood working skills are simplistic.
-- I was bradd on KLOV --
  • Last login:Today at 06:04:22 pm
« Reply #5 on: March 11, 2014, 03:57:22 am »
Have you read the mounting hardware and joystick mount sections of the FAQ?
steinar-t
  • Last login:April 21, 2019, 02:31:15 pm
« Reply #6 on: March 11, 2014, 06:54:56 am »
Here is how i mounted mine. I used a router thought. ;D
You could du this with 2 thinner layers of mdf maybee? then you woud not need the router.(Get a router :applaud:)
EMDB
  • Project RetroCade
« Reply #7 on: March 11, 2014, 09:13:25 am »
The only way to mount a joystick without using a router is to under mount (see FAQ) and use a longer shaft...
« Reply #8 on: March 11, 2014, 12:55:38 pm »
For 3/4 MDF:  I picked up one of these metal templates from Bob Roberts.  Only $2 plus shipping.  You simply line it up underneath and then mark your drill holes for the screws.  You can then install the joystick bases from underneath the panel by first drilling a shallow pilot hole smaller than the actual screw.  I used 1" long zinc plated wood screws from Home depot or Lowes at about $4 per 100.
The size is #10. The box would then be marked 10 X 1.
I've had my CP for years and they have never given me any issues.  I believe NorthCoast customs has the same mounting method.  (They provide pre-drilled holes for your screws)
Find it here: (search for the term "joystick template" under the tools section)
http://therealbobroberts.net/parts.html#tools
DeLuSioNaL29
shayvidas
« Reply #9 on: March 11, 2014, 02:48:24 pm »
 :laugh2: :laugh2: :laugh2: :laugh2: :laugh2: :laugh2: :laugh2:
ohh if only ... man .. if only..
it's like.. all my trubles in life would be gone..
shayvidas
« Reply #10 on: March 11, 2014, 02:50:23 pm »
if for a second i'd leave.. the "get a longer shaft" joke aside..
where do i really get a longer shaft for my joystick ?
« Reply #12 on: March 11, 2014, 03:03:11 pm »
Helps when you mention which joystick you're using.  ::)
There are other ways, but they are less commonly used.
Slagcoin shows a layering method here that you could achieve without a router.
severdhed
  • RIP Dinosaur Hippo
« Reply #13 on: March 12, 2014, 04:49:51 pm »
undermounted in a recessed area to raise the height of the stick, bolted in from bottom into flush mounted T-nuts
spend $40, get a cheap router and bits from harbor freight.. they are not great for big jobs, but more than enough for recessing joyticks and routing tmolding slots.
http://www.harborfreight.com/1-4-quarter-inch-trim-router-44914.html#.UyC_E_ldUU4
http://www.harborfreight.com/5-piece-m2-hss-router-bit-set-43695.html#.UyDIUPldUU4
eds1275
  • Last login:March 11, 2026, 11:07:08 am
  • Rock and Roll!
« Reply #14 on: March 12, 2014, 05:59:39 pm »
I undermounted my joysticks and regretted it. But the other day I put some washers on the joystick shaft to eat up some of the real estate of the threads, and that $0.10 idea really saved me from cutting a new panel.
