Author Topic: CRT_emu drivers and SSF saturn emulator  (Read 3330 times)
Tzakiel
  • Last login:March 02, 2019, 12:59:01 pm
« on: February 20, 2014, 11:52:38 am »
Not a groovymame question per se but related to Calamity's drivers.
I am running winXP32 with the crt_emu drivers and can't seem to get SSF to run.  Windows says I have directx9.0c, which I have read is the right ver, but the program just refuses to run, it crashes on startup.  Wondering if it could be a video driver issue since I have seen that as the other thing to try (update video drivers)
My Fighter CRT Cabinet Thread: Tzakiel's 2P Cabinet
  • Last login:Today at 05:45:19 am
Re: CRT_emu drivers and SSF saturn emulator
« Reply #1 on: February 20, 2014, 12:02:25 pm »
Hi Tzakiel,
When a program crashes, it isn't fair to assume it is a video driver issue. It is the responsibility of a programmer to make sure his program doesn't crash. If it was a video driver issue, you'd probably see something serious like a blue screen.
Probably SSF is assuming something that is not true, like a certain video mode must be present (800x600?), and it's failing because of that.
stellarola
  • Last login:June 24, 2020, 11:46:59 pm
  • .::For the love of the game::.
« Reply #2 on: February 20, 2014, 04:42:41 pm »
Hi Tzakiel,
That's exactly the same issue I had. You'll need access to a higher resolution than 640x480. Not as good, but another option would be Yabause (Sega Saturn emulator). Hope this helps.
Tzakiel
« Reply #3 on: February 20, 2014, 06:01:54 pm »
OK... thanks for the info.  Looks like there is no way to get it going on a 480i display then?  I'll look into that other emulator.
bulbousbeard
  • Last login:August 25, 2015, 11:58:25 pm
« Reply #4 on: February 20, 2014, 10:13:55 pm »
Just use MESS. It actually runs some games that SSF doesn't (but SSF runs some games that MESS doesn't).
MESS with HLSL looks awesome anyway.
Tzakiel
« Reply #5 on: February 20, 2014, 11:01:15 pm »
Mainly I am trying to run radiant silvergun, astal, guardian heroes. Especially radiant- mame can't se to handle it well even with my 4.2ghz i5.
