Author Topic: Terminator 2 gun to mame (diagrams using an A-pac and solution for the Recoil)  (Read 5733 times)
Cheesy59
  • Last login:November 09, 2015, 03:56:11 pm
Hello friends,
I've just bought a Terminator2 gun
I try to hook up it to A-Pac to run mame using a A-pac.
No problem with the buttons, I will do as mentioned here:
But I'm wander how to plug the solenoid considering the original wiring:
I find an old post with a diagrams but it's for a force feedback motor
I know a member called retrorepair succeed to make it with a Revolution X cab but I don't know how he did it
Thanks for your Reading and sorry fr my English I'm french  :P
You'll need MAMEHooker to translate the output signals from MAME to an output device.
http://dragonking.arcadecontrols.com/static.php?page=aboutmamehooker
(see links to tutorials on right side of page)
For an output device, you can use a Pac-Drive from Ultimarc or LED Wiz from Groovy Game Gear.
There are also ways to use the pins on a parallel port, but that can be difficult to accomplish with newer 64 bit operating systems.
The output device will need to trigger a transistor or solid state relay.
On its own, the output device cannot handle the current or voltage required to trigger the solenoid.
« Last Edit: February 17, 2014, 01:54:34 pm by BadMouth »
Cheesy59
Thanks you for your reply BadMouth
 Damn so it won't be so easy  :embarassed: And my Ultimarc order wich was sent this morning...  :banghead:
Nevermind, My original plan was building an alternative panel with this T2 gun to my cab in order to do not damage or denature it (In fact I own a full working Revolution X cab)
Do you thin I can cleanly use the cab wiring to get the solenoid working?
« Last Edit: February 17, 2014, 04:04:08 pm by Cheesy59 »
