Author Topic: Blast/Astro city nanao monitors and VGA card with native res  (Read 2073 times)
Tzakiel
  • Last login:March 02, 2019, 12:59:01 pm
« on: February 13, 2014, 09:23:30 am »
I am looking into getting a new astro city or blast city with the original Nanao arcade monitor... does anyone know what connection these monitors use for input?  I plan on using CRT_emu drivers and compatible video card as I have done for my existing build at native resolution with groovymame (but for my build I had to use a transcoder to get from vga to component as I am using a TV).  Just wondering what hardware I need to make the connection to a Nanao monitor from VGA. If it's VGA/RGB in I guess I am good to go right from the card to the monitor?
I'm thinking I might need a J-pac to send video through, instead of just an i-pac for this build, is that right?
EDIT: Looks like the monitor takes an RBG header of some kind... not standard VGA at all.  So I assume I also need a special cable.
« Last Edit: February 13, 2014, 09:34:49 am by Tzakiel »
My Fighter CRT Cabinet Thread: Tzakiel's 2P Cabinet
twistedsymphony
  • Last login:February 03, 2024, 11:13:51 pm
  • Play stupid games... win stupid prizes.
    • solid-orange.com
    • CollectorsEdition.org
Re: Blast/Astro city nanao monitors and VGA card with native res
« Reply #1 on: February 13, 2014, 10:01:42 am »
It varies from monitor to monitor... I've seen them with VGA ports as well as more generic arcade monitor headers. Most of these cabs are wired for JAMMA so I'd recommend just getting JPAC and be done with it.
I have a few "VGA" monitors, you'll still need to use Soft 15K to force 31K output modes since not all 640x480 modes are supported by these monitors and Windows hates to go below 800x600.
grantspain
« Reply #2 on: February 13, 2014, 02:36:54 pm »
if your cabs are all original the blast city will have a tri sync nanao ms2930 or ms2931 monitor,Astro city will have nanao ms8-29 dual sync(manual)and a New astro city will have a nanao ms9-29 dual sync(manual)
Tzakiel
« Reply #3 on: February 13, 2014, 03:52:31 pm »
Yeah I'm quite familiar with outputting 15khz to a vga cable using crt emu drivers and groovymame. My only question is what cable or hardware/amplifier do I need to hook up the vga to nanao monitor? I see ultimarc sells a breakout cable or an amplifier adapter as well as j pac... Just not sure what I really need.
