Author Topic: USB mounted connectors - forum post?  (Read 6812 times)
s_busby_uk
  • Last login:August 22, 2017, 02:28:51 pm
« on: December 18, 2013, 04:49:07 pm »
Hi all
I've been looking for ages trying to find a forum post that had some suggestions for something like this (not JUST this, mind - a few other alternatives):
Struggling to find it and search terms like "USB" are a bit too broad for narrowing it down it seems.
Is anyone else cleverer than I am and able to link me to it? Sorry to be so pathetic at tracking this down!
codemonkey76
  • Last login:December 21, 2013, 06:35:11 am
keilmillerjr
  • Web Developer.
Re: USB mounted connectors - forum post?
« Reply #2 on: December 18, 2013, 05:30:08 pm »
I purchased two of these. They were not cheap ($21.99), but are of excellent quality and look great! Mount them in a hole just like an arcade button. The cover not shown is just a rubber cover that is attached to the unit so you don't loose it.
Clarion CCAUSB USB 2.0 Extension Cable with Integrated Cover
http://www.amazon.com/Clarion-CCAUSB-Extension-Cable-Integrated/dp/B001GXQMXE
  • Last login:Today at 05:04:51 am
« Reply #3 on: December 18, 2013, 05:59:17 pm »
You can buy Neutrik NAUSB-W-B feedthrus at Focus Attack, Allied Electronics, or Mouser.
They also come in nickel. (P/N NAUSB-W)
s_busby_uk
« Reply #4 on: December 18, 2013, 06:06:36 pm »
Perfect PL1, I think those are the ones I had in mind. Thanks for putting the part number too, much easier to track down!
Thanks everyone else too, most useful.
ArcadeNerd
  • Last login:July 19, 2021, 10:16:00 am
  • When's it my frickin turn to play?!?
« Reply #5 on: December 19, 2013, 12:01:05 pm »
I second these.  I put one or two each on my games that have a PC in them.  Some machines I put one in them and run a USB to a 5V charger on the power strip so that I can attach and power USB toys and such to my cab.
s_busby_uk
« Reply #6 on: December 19, 2013, 12:35:02 pm »
Yeah I figure they're ideal for attaching gamepads and particularly keyboards and mice for when some PC admin is needed. I'm planning a slimline cabinet so don't want to house any of these things inside it if I can help it.
DarakuTenshi
    • Card Fighters Project
« Reply #7 on: December 19, 2013, 01:49:59 pm »
I think the Neutrik are the best looking out of them and they are simple to install. On top of that it looks natural rather than having to contrive a way to install them in the cabinet.
    • GroovyGameGear.com
« Reply #8 on: December 19, 2013, 02:01:54 pm »
USB extension cable, a small slot in your desired panel and some hot melt glue.  If you want to get fancy, you can add a faceplate, but just a simple slot would be less obtrusive.  Very inexpensive and not too difficult to do.
« Last Edit: December 19, 2013, 06:42:58 pm by RandyT »
chopperthedog
  • Last login:Today at 06:24:48 am
« Reply #9 on: December 19, 2013, 06:13:13 pm »
USB extension cable, a small slot in your desired panel and some hot melt glue.  If you want to get fancy, you can add a faceplate, but just a simple slot would less obtrusive.  Very inexpensive and not too difficult to do.
As said above, but I went the fancy route and used 2 button hole plugs that I had on hand.
good day.
Brian74
  • Yep... I built that!!
mgb
  • North East, US
« Reply #11 on: December 19, 2013, 09:52:29 pm »
I definitely agree. and Neutrik makes great products.
go with the neutrik pass throughs as PL1 showed. they're easier to install and won't look hacked.
« Reply #12 on: December 19, 2013, 10:09:17 pm »
This may be, but they aren't very attractive for a finished surface.  Something about a square connector jutting out in a hollow round housing that throws the aesthetics of it off.  Maybe it's just me :)
« Reply #13 on: December 19, 2013, 11:45:23 pm »
Just put them on the back/bottom instead of the front -- out of sight, out of mind.   >:D  :lol
Neutrik also makes the SCDX covers in several colors.
mgb
  • North East, US
« Reply #14 on: December 20, 2013, 10:22:39 am »
Those covers really make for a slick looking install
Sitnalta
  • Last login:November 02, 2024, 11:12:43 am
« Reply #15 on: January 03, 2014, 03:55:28 pm »
Damn those covers look perfect, i just ordered 2 on ebay :)
« Reply #16 on: January 03, 2014, 04:42:21 pm »
These don't look half-bad either  ;D
« Last Edit: January 07, 2014, 04:37:53 am by RandyT »
Slippyblade
« Reply #17 on: January 03, 2014, 06:58:03 pm »
Are those available through GGG?  I just nosed around and couldn't find em...
Unstupid
« Reply #18 on: January 03, 2014, 09:59:16 pm »
The Neutrik connectors are cool... Only problem is they look like ass.  After a search high and low for something that looked nice, I ended up just buying solder mount connectors from mouser and cutting a square hole in the back of the box:
mgb
  • North East, US
« Reply #19 on: January 03, 2014, 10:11:47 pm »
Yeah,
  That's looks good
« Reply #20 on: January 07, 2014, 04:39:22 am »
They are now.  Just added them. :)
