Author Topic: .  (Read 12364 times)
ChanceKJ
« on: November 23, 2013, 07:00:00 pm »
« Last Edit: March 18, 2021, 10:57:15 pm by ChanceKJ »
stigzler
    • Mago Arcade
Re: Backlit T-Moulding: Proof of Concept.
« Reply #1 on: November 23, 2013, 07:25:04 pm »
It's a good concept, but having some of that waterproof led strips stuff - I'd imagine feeding the length along the entire length of the t-molding channel would be a nightmare. Guess brainstorming some ideas:
- oil
- do it in sections
- use the non-waterproof stuff - thinner profile
- fiber-optic cable?
also, using that channel router bit around your cab sides is gonna take a really steady hand!
Love the concept though, especially with these mutli-colour strips you can get - cab edges with cycling colours! how cool would that be? Mood Cabs :)
ChanceKJ
« Reply #2 on: November 23, 2013, 07:32:33 pm »
« Last Edit: March 18, 2021, 10:57:27 pm by ChanceKJ »
matt4949
« Reply #3 on: November 23, 2013, 09:16:26 pm »
How about contacting your T-molding supplier. Surely you could order some prior to being coated?
kiwasabi
  • Last login:September 28, 2014, 12:14:51 pm
« Reply #4 on: November 24, 2013, 03:58:00 am »
Looks like a couple manufacturers have beaten you to it. Personally I think it looks tacky.
http://arcadeheroes.com/2013/11/23/iaapa-2013-summary-plenty-options-western-arcades-going-2014/
stigzler
    • Mago Arcade
« Reply #5 on: November 24, 2013, 01:18:28 pm »
Hmmm - it don't look good in those photos, but if you could get it more diffuse rather than 'blothcy' could still look good.
Zzap
  • Last login:September 06, 2021, 03:12:54 am
« Reply #6 on: November 24, 2013, 06:58:25 pm »
How bright is EL-wire? That could run in a normal t-moulding slot, but I don't know if it would be bright enough, and would really only light up the centre strip of the moulding.
Fursphere
  • Last login:March 13, 2026, 04:45:20 pm
« Reply #7 on: November 24, 2013, 07:54:20 pm »
How are you going to use the channel router bit on corners?  If you had a 3d axis cnc router you could do it.  But freehand?  eeek....
ChanceKJ
« Reply #8 on: November 24, 2013, 08:25:23 pm »
« Last Edit: March 18, 2021, 10:58:38 pm by ChanceKJ »
mgb
  • North East, US
« Reply #9 on: November 24, 2013, 09:46:45 pm »
Both of those look more like rope lighting fixed on the edges
ChanceKJ
« Reply #10 on: November 24, 2013, 09:48:29 pm »
« Last Edit: March 18, 2021, 10:58:50 pm by ChanceKJ »
« Reply #11 on: November 24, 2013, 10:52:28 pm »
EL Tape would work well but you would have to remove the barb completely and adhere the molding in some other fashion.
« Reply #12 on: November 25, 2013, 12:49:39 am »
I think the best bet would be a black-light reactive type of t-molding. I'm not sure any sort of lighting would ever diffuse the way we'd ever want it to. But good try, Chance.  :cheers:
kiwasabi
« Reply #13 on: November 25, 2013, 01:59:56 am »
From my own testing with LEDs behind my marquee, I found that they need to sit back at least 1.5" to be fully diffused. So I'm not sure how you'd get this to work other than having some plastic in your cabinet (or the whole cabinet made out of plastic) and backlighting that with the LEDs set back. I don't think it's possible to make the LED t-molding idea fully diffused though.
ChanceKJ
« Reply #14 on: November 25, 2013, 03:34:12 am »
« Last Edit: March 18, 2021, 10:58:57 pm by ChanceKJ »
kiwasabi
« Reply #15 on: November 25, 2013, 05:01:39 am »
I'm not trying to crap on your thread, just was putting in my two cents. You're probably right that it's doable with enough plastic in front of the LEDs.
ChanceKJ
« Reply #16 on: November 25, 2013, 05:24:36 am »
« Last Edit: March 18, 2021, 10:59:01 pm by ChanceKJ »
  • Last login:March 14, 2026, 08:11:32 pm
« Reply #17 on: November 25, 2013, 10:02:41 am »
Part of me wants to lament that you have unleashed yet another LED horror upon this hobby.  The other part says that looks kinda cool and it hopes you figure it out.
 :dunno
« Reply #18 on: November 25, 2013, 10:15:31 am »
If I was to implement this I wouldn't care if the LEDs were fully defused or not.
I would. Otherwise it'll look like those posted examples.  :dunno
Again, experimentation is good- maybe it'll lead to something in the future.
Sarver Systems
  • Last login:October 07, 2020, 12:46:05 am
« Reply #19 on: November 25, 2013, 12:12:59 pm »
Why use T-molding at all? I think I saw some LEDs on long rolls that were the same width as a cabinet.
« Reply #20 on: November 25, 2013, 12:27:46 pm »
LEDs would be dotted. I think ideally, most people who would want this functionality would want an evenly lit, unbroken line made entirely of the T-molding.
mgb
  • North East, US
« Reply #21 on: November 25, 2013, 12:37:14 pm »
Yeah I'd think just having LEDs in place of t molding would look hokey.
Sarver Systems
« Reply #22 on: November 25, 2013, 12:55:16 pm »
EL tape would be the way to go then.
eds1275
  • Last login:March 11, 2026, 11:07:08 am
  • Rock and Roll!
« Reply #23 on: November 25, 2013, 02:08:47 pm »
I bought this finish stripper that took the finish off of a piano in just a few minutes (per piece I was stripping). Assuming it doesn't just melt the t-molding I think it might work on that shiny t-molding.
ChanceKJ
« Reply #24 on: November 25, 2013, 02:46:19 pm »
« Last Edit: March 18, 2021, 10:59:12 pm by ChanceKJ »
« Reply #25 on: November 25, 2013, 02:52:38 pm »
...experimentation is good- maybe it'll lead to something in the future.
Funny, that's what I use to say to the girls in college.
 :o
stigzler
    • Mago Arcade
« Reply #26 on: November 25, 2013, 03:39:35 pm »
So did I, but after a succession of doors being showed to me:
I bought this finish stripper.
« Reply #27 on: November 25, 2013, 03:41:19 pm »
:pics of the Finnish stripper, or it didn't happen.
ChanceKJ
« Reply #28 on: November 25, 2013, 03:41:40 pm »
« Last Edit: March 18, 2021, 10:59:22 pm by ChanceKJ »
stigzler
    • Mago Arcade
« Reply #29 on: November 25, 2013, 03:50:07 pm »
« Reply #30 on: November 25, 2013, 03:51:02 pm »
I'd hit it.  :afro:
CoryBee
  • Bopity Boopy
« Reply #31 on: November 25, 2013, 05:01:44 pm »
michelevit
  • Last login:December 25, 2024, 06:57:41 pm
« Reply #32 on: November 25, 2013, 07:27:18 pm »
I'm stuck in the golden era...
No lit joystick ball stops, buttons, or t-molding for my cabs.
Seems like a novel undertaking, but a little too detracting for my taste.
I like to focus on whats happening on the screen, not elsewhere...
