Author Topic: MAME 127  (Read 2603 times)
trendy21
  • Last login:January 27, 2023, 08:11:48 am
  • Alright, Alright, Alright
MAME 127
« on: November 22, 2013, 09:33:47 am »
IM RUNNING MAME 127 WITH GAME EX AND JOYSTICK AND BUTTONS WORK IN GAME EX MENU UNTIL I SELECT A GAME AND GO INTO MAME. I TRIED HITTING TAB IN THE GAME AND ONLY DIP SWITCHES AND COUPLE OTHER NON RELEVANT CHOICES COME UP. I THOUGHT ANOTHER MENU SHOULD COME UP FOR USER INTERFACE AND PLAYER CONTROLS. I CANT OR DONT KNOW WHERE TO LOOK FROM HERE TO ENABLE OR PROGRAM NOT ONLY ONE GAME BUT ALL OTHER PLATFORMS. I CHANGED FROM SLIKSTIK TO ULTRASTIK AND I ONLY CHANGE I MADE WAS TO DISABLE SLIKSTIK IN GAME EX SETUP MENU. THANKS
mgb
  • North East, US
MAME 127
« Reply #1 on: November 22, 2013, 09:45:59 am »
Lets use our inside voice.
I'm not sure why tab isn't showing Controls (general) or controls (this game).
But have you looked into the mame.ini file in your mame directory. Maybe the new stick comes up as a joystick and that would need to be enabled in the ini to get the controls working.
   What flavor if mame are you using, command line, mameui, etc?
trendy21
Re: MAME 127
« Reply #2 on: November 22, 2013, 09:58:46 am »
sorry for caps lock, its command lind mame and joysticks is set to 1, does it matter that they are ultrastik? are they seen as something else, or could u send me an example of wahat the ini file should read , thanks
mgb
  • North East, US
MAME 127
« Reply #3 on: November 22, 2013, 10:16:05 am »
In the mame folder, isn't there a slickstik cfg file that may need to be removed.
I'm not sure as I've never had either of those sticks and I've never seen the tab menu not work right.
trendy21
Re: MAME 127
« Reply #4 on: November 22, 2013, 10:20:44 am »
yes i will delete that and mess with the tab button in all platforms and several games, i know i got to it last week when joysticks werent working, now that i got that fixed i cant seem to make any headway, this is the most frustrating intersting thing ive got myself mixed up in but now i know im new to this but just cant let it beat me! thanks
mgb
  • North East, US
MAME 127
« Reply #5 on: November 22, 2013, 10:40:15 am »
And once you are able to get into settings, you're gonna want to go into controls for all games (general) and set them to the ultra sticks.
trendy21
Re: MAME 127
« Reply #6 on: November 22, 2013, 11:16:45 am »
and is that in mame.ini or mame.cnfg in the mame folder that looks like the note with yellow stamp
mgb
  • North East, US
MAME 127
« Reply #7 on: November 22, 2013, 11:24:50 am »
That's when you hit tab while in game
mgb
  • North East, US
MAME 127
« Reply #8 on: November 22, 2013, 11:34:05 am »
If there is a slickstik cfg, it will be in the cfg folder within the mame folder.
You also may have to delete your default.cfg and start new.
trendy21
Re: MAME 127
« Reply #9 on: November 22, 2013, 12:03:23 pm »
do u think deleting the default config file will fix the tab command, and how hard is it to start new as i am new but know some from messing with it, or does it recreate and you just make changes like enable joystick to 1, thanks again at least its narrowed down to that issue i really appreciate the response. ill copy that file before i delete it for a reference
trendy21
Re: MAME 127
« Reply #10 on: November 22, 2013, 12:06:57 pm »
by the way is there an easier way to use mame instead of command line, like the UI and get a newer version or is it to involved for what im running. ive downloaded it and messed with it on my laptop just to not mess up the files but navigation and overall beginner use is easier from what ive done so far
B2K24
  • Last login:June 10, 2025, 10:17:56 am
Re: MAME 127
« Reply #11 on: November 22, 2013, 12:34:41 pm »
It really doesn't get much easier than the official binary and QMC2
http://wiki.batcom-it.net/index.php?title=The_%27ultimate%27_guide_to_QMC2
I also enjoy ML TNG (MAMELOAD)
mgb
  • North East, US
MAME 127
« Reply #12 on: November 22, 2013, 04:16:57 pm »
There won't be much to starting over.
You'll just need to run mame createconfig and go into a game and hit tab. Then enable joystick in the ini again.
  Then I'd think you should see the normal menu and you can select controls general and set all your directions and buttons.
trendy21
Re: MAME 127
« Reply #13 on: November 23, 2013, 12:56:03 am »
well I got controls to work finally but still when I hit tab in the game it only gives me dip switches, book keeping info and return to menu never get the full menu like ive seen on others should I update mame to new version would that help any going from 127 to 151 version. also only mame games work my other emulators like Nintendo and sega nothing works so I guess ill keep trucking to find out how to program those I assume its similar to the mame config, thanks for getting me this far
mgb
  • North East, US
MAME 127
« Reply #14 on: November 23, 2013, 10:42:05 am »
You'll have to go into the other emulators and change the keys to match the new stick.
That's weird about the mame menu but I'm sure someone here has dealt with it before
trendy21
Re: MAME 127
« Reply #15 on: November 23, 2013, 12:14:43 pm »
yeah that's why I want to update if it wont cause problems, because im updating game ex for certain bug fixes. can I leave my directories for roms and other folders the same in game ex settings or would I have copy everything and put in new settings and folders its been this way for four years and want to take advantage of new games and fixes and user interfaces. cant be to hard unless a lot of roms quit working
mgb
  • North East, US
MAME 127
« Reply #16 on: November 23, 2013, 03:32:54 pm »
Updating things shouldn't give you any problems.
I'm not sure of the workings of gamex but I imagine its like all other front ends and just needs to be steered toward the directory files in settings
