Author Topic: (almost) Universal Joystick Adapter Plates  (Read 12148 times)
cybermat
  • Last login:March 05, 2025, 12:14:11 pm
Re: (almost) Universal Joystick Adapter Plates
« Reply #40 on: February 23, 2016, 11:07:09 am »
Sorry for necroposting, but when you speak about "X-arcade universal plate" you mean this item ? http://www.paradisearcadeshop.com/mounting-plates/1280-universal-arcade-joystick-adapter-plate.html
It would fit perfectly without any woodworking ?
« Reply #41 on: February 23, 2016, 11:12:06 am »
I don't have any experience with the plate, but I'll go ahead and give my $.02 in case Armi doesn't post to answer your question.
I had an x-arcade and swapped IL sticks into it.  They were a direct swap and bolted right in.
So if this thing has the same footprint as an IL stick, it should work fine.
armi0024
  • Last login:January 12, 2023, 09:57:36 pm
« Reply #42 on: February 23, 2016, 11:55:29 am »
That is exactly what the X-arcade plate is for.  We named it that because it's just a little smaller than the main Universal plate and fits down into the routed out section without requiring any modifications to an X-arcade stick
« Reply #43 on: February 23, 2016, 12:32:05 pm »
I see nothing named "X-arcade plate" and there is no mention of X-arcade in the description.
I believe that's why OP was asking for clarification.
So...he needs to buy the IL Universal plate?
armi0024
