Author Topic: Share silver strike bowling controls with mame pc  (Read 2938 times)
Brian74
  • Yep... I built that!!
« on: November 07, 2013, 08:49:33 pm »
I wanna run a mame pc in conjunction with the silver strike bowling pc. There is a I/O board, but its not jamma. I would like to share the trackball and other buttons with my pc.  Any help would be great.
Sent from my SGH-M919 using Tapatalk 2
benrkay
  • Last login:November 19, 2013, 09:51:43 pm
Re: Share silver strike bowling controls with mame pc
« Reply #1 on: November 08, 2013, 01:02:41 am »
split the wires. send one set to the board and the other to the pc. should be fine as long as you dont run them both at the same time
  • Last login:Today at 06:06:48 am
« Reply #2 on: November 08, 2013, 02:45:07 am »
Several relays or a multi-pole switch like an old parallel port printer switch would probably work.
Probably best to keep both systems on at the same time and just switch the buttons, button ground, and the four data lines (X1, X2, Y1, and Y2) from the trackball.
Also, how do you plan on switching the video? (not sure how well that will work with a relay or printer switch   :dunno)
Brian74
« Reply #3 on: November 08, 2013, 09:09:07 pm »
Thanks for the replies guys. I took a shot by plugging in the I/O board into my mame pc. It used a generic usb hub for one, but couldn't find drivers for the other two. Kinda thought it wouldn't, but didnt hurt to try. When I did, the ssb threw a error code. I was thinking a dtdp switch, but I need one that can use 18 wires I have some that has 12 posts. Guess I could use two of them. For the video and audio, I have a kvm switch.
chopperthedog
  • Last login:Today at 06:55:47 am
« Reply #4 on: November 08, 2013, 09:36:52 pm »
This thread may spark some ideas. forum.arcadecontrols.com/index.php/topic,132576
good day.
Brian74
« Reply #5 on: November 09, 2013, 04:48:35 am »
Thanks chopper, only problem is, this isnt jamma. I have seen other I/O boards that have jamma finger boards, but this one doesn't.
