November 18, 2025, 06:25:47 am
here ya go.good day.
Is it possible to have use push button instead of the switch?
Quote from: VoltaTom on November 07, 2013, 07:46:36 pmIs it possible to have use push button instead of the switch?The rocker switch (master power switch for cab) is separate from the momentary pushbutton. (computer motherboard switch)
There are threads like this one that show how to make your own smart strip using a relay.You could use an arcade pushbutton to apply power to the relay.
Just curious, VoltaTom, but where did you find that three-outlet power strip? I've been looking for something similar, but can only find four-outlet types.
Ah ha. Thanks. Will have to poke around the 'ole Dollar Tree/Store/Family then. Harbor Freight only had the a-four-mentioned strip.
And speaking of Dollorama, (if you speak french)
