Author Topic: Noob wiring question (power)  (Read 2665 times)
VoltaTom
  • Last login:November 11, 2018, 09:42:10 pm
« on: November 07, 2013, 06:42:00 pm »
I need some help as I don't know much about wiring other than for a control panel. Just yesterday I shorted my smart power strip making it garbage... Needless to say I need help and advice.
What I want to know is can I wire this cheap power strip to the power socket with the switch in between. The socket and switch will be on the back of my bartop.
Is it even possible? Am I missing something?
Sent from my iPhone
chopperthedog
  • Last login:Today at 05:05:56 am
Re: Noob wiring question (power)
« Reply #1 on: November 07, 2013, 06:49:40 pm »
here ya go.
good day.
VoltaTom
« Reply #2 on: November 07, 2013, 07:46:36 pm »
here ya go.
good day.
Awesome thanks. That makes it very simple!
Is it possible to have use push button instead of the switch?
  • Last login:Today at 04:11:49 am
« Reply #3 on: November 07, 2013, 08:10:46 pm »
The rocker switch (master power switch for cab) is separate from the momentary pushbutton. (computer motherboard switch)
VoltaTom
« Reply #4 on: November 07, 2013, 08:49:58 pm »
I've got to get a cooler switch then! Wanted to use an arcade button but don't need to turn on a computer, just power.
« Reply #5 on: November 07, 2013, 10:01:41 pm »
There are threads like this one that show how to make your own smart strip using a relay.
You could use an arcade pushbutton to apply power to the relay.
« Last Edit: November 07, 2013, 10:11:48 pm by PL1 »
VoltaTom
« Reply #6 on: November 08, 2013, 01:55:26 pm »
I've seen that thread before, it is pretty cool!
It would be awesome to be able to make one of those but I'm afraid it is beyond my (limited) electrical skills.
roknrol
  • Last login:October 30, 2025, 03:51:17 pm
« Reply #7 on: November 12, 2013, 02:03:26 pm »
Just curious, VoltaTom, but where did you find that three-outlet power strip? I've been looking for something similar, but can only find four-outlet types.
VoltaTom
« Reply #8 on: November 12, 2013, 02:37:55 pm »
I purchased that stellar piece of equipment from the dollar store. Dollarama here in Canada. Cost me $2 - which is why I went ahead and cut it up to check it out.
roknrol
« Reply #9 on: November 12, 2013, 06:00:36 pm »
Ah ha. Thanks. Will have to poke around the 'ole Dollar Tree/Store/Family then. Harbor Freight only had the a-four-mentioned strip.  :lol
VoltaTom
« Reply #10 on: November 12, 2013, 09:56:16 pm »
That four-outlet strip was $3 from Dollarama. I didn't spring for the fourth outlet as it was green (for under Xmas trees) and expensive....  :P
ppv
  • Last login:October 16, 2020, 03:08:56 pm
  • The cheap@ss gamer
« Reply #11 on: November 13, 2013, 12:09:12 pm »
Thanks for that! will be a big help!
And speaking of Dollorama, (if you speak french)   :laugh2:
Doing arcades, the cheap@ss way!
First Project : ttp://forum.arcadecontrols.com/index.php/topic,151071.0.html
Next one : The Token Muncher [urlhttp://forum.arcadecontrols.com/index.php/topic,135417.0.html[/url]
VoltaTom
« Reply #12 on: November 13, 2013, 10:55:33 pm »
What did I just watch....
