Author Topic: 2-player XBOX inspired Weecade inspired Bartop  (Read 29454 times)
jammin0
Re: 2-player XBOX inspired Weecade inspired Bartop
« Reply #40 on: November 22, 2013, 08:09:42 pm »
I like it.
Yeah those controllers are and awesome find, i've bought a few myself.
You have the remote option like jammin0 is using or you can get the mini, i eluded too in a prior post.  Its just 3 buttons and you cycle through the same effects as the remote option.  The remote just gives you direct access to each mode.  You can get these for about 1.50 on ebay.  Just search MINI LED CONTROLLER.
Also, Jammin0, just in FYI, those controllers work with 5v as well not just 12v.
Also, i've crammed a few xboxes in bartops, so i'm interested in your technique and part placement.  If your softmodding and not doing a TSOP, i have some ideas for you to get rid of the flubber and the xbox intro sound.
I can also show you how to get your power button to stay lit while the machine is off, its a pretty cool touch. HMM, what would be cool is to have a power button that shifted colors like the marquee....
Awesome work man....
Cool, I might have to pick your brain when I'm getting to those last touches.  I actually don't mind the flubber since I'm doing the whole xbox theme.  I am going to need some help making some custom vision menus to get to XBMC and coinops.
woohoo, look what came in the mail.  Thanks for getting them to me so fast Kevin.
sharpfork
    • KADE
« Reply #41 on: November 22, 2013, 11:07:46 pm »
I'm glad to see the DIY KADE miniArcades as a part of this cool project.  Let me know if you have any questions.
Start here: http://kadevice.com/how-to-assemble-a-diy-miniarcade/
jammin0
« Reply #42 on: November 24, 2013, 01:56:39 pm »
Just plugging away at it.  Got the shell bondoed, sanded, and primed.  Took a second today to work on the KADEs.  Let me just say that they are super slick.  Took me about 20 mins to build the 2 kits including the time it took to heat up the iron.  5 more minutes to install the software and flash them with the xbox firmware.
Plugged them both in and they work just as advertised. For anyone on the fence about grabbing these, it is totally worth the extra couple of dollars over controller hacking.   Probably saved myself at least an hour, probably closer to 2 and not a single burned fingertip.  :applaud:
  • Online Online
  • Last login:Today at 02:44:18 pm
« Reply #43 on: November 25, 2013, 12:21:33 am »
Looks good so far.
Don't forget to clean off that excess flux -- Q-tips/old toothbrush/acid brush and isopropyl alcohol are your friends.   ;D
jammin0
« Reply #44 on: November 25, 2013, 10:53:09 am »
Looks good so far.
I had a question about that.  I was going to clean them but then I realized that I was out of isopropyl and haven't had a chance to get to the store.  I do have acetone free nail polish remover, and denatured alcohol, would either of those do the trick without leaving more residue?
  • Online Online
« Reply #45 on: November 25, 2013, 12:54:41 pm »
Denatured alcohol will work fine.   :cheers:
jammin0
« Reply #46 on: November 25, 2013, 11:01:28 pm »
Ok, here are my ideas for the control panel.  I'm going to try and squeeze in the original DVD drive, the original power and eject buttons without new and improved color changing ring on the eject button, and players 3 and 4 controller ports.
What about buttons, do you think I have enough?  I was going to put the two trigger buttons for P1 on the left and right side but I might not.  Anyone who has Vision setup have any opinions about all those buttons.  I have the controller ports if you absolutely have to play an xbox game or something that requires more buttons or joysticks.  I was thinking about the two buttons above the DVD drive as Shift and Coin.  Any thoughts about that?  I want to do the shift button so that it will push and stay engaged so that I can use the analog on the joysticks but I haven't really tried that on any of the games to see if I like it.
jammin0
« Reply #47 on: November 26, 2013, 10:40:43 am »
I was just reading on the KADE forums that the shift button has a double click to lock feature.  Is this true?
  • Online Online
« Reply #48 on: November 26, 2013, 11:23:47 am »
That is correct for the firmwares with shifted functions. (MAME multi-mode uses HWB to change maps instead of shifting functions)
Accidently triggered the shift-lock several times while doing some beta testing and almost submitted a bug report to the team before sorting it out.     :lol
sharpfork
    • KADE
« Reply #49 on: November 26, 2013, 04:58:30 pm »
I lay my buttons out the same way and don't really add much more.  You might have to do a bit of remapping on some games.  You can do without the left and right trigger as far as I'm concerned.
I like to add an exit game button and map the shift of that button to the return to dash option.  Depending on your bios, this will let you back out of xBox games.  I also like to disable the back+start = exit in the KADE loader so kids adding credits and hitting player start while playing beat em ups don't accidentally back out of the game.  If you chose this option you have to add the exit game button.
I also reccomend you have two coin buttons, one for p1 and another for p2.
jammin0
« Reply #50 on: November 26, 2013, 05:29:24 pm »
So as far as admin buttons . . .
I can get away with P1 start P2 Start P1 Coin P2 Coin Shift and Back?  I can always plug in a controller for any other admin things in case I need the analog stick click or anything else.
I know what you mean about the accidental Coin + Start buttons as I did that once myself on a game of bubble bobble at the final boss.  My bro and I had been playing for a good hour or so.  Is that mapping something that you can change in Coinops/Vision?  Or does the Kade prevent the combined press?
sharpfork
    • KADE
« Reply #51 on: November 26, 2013, 07:50:28 pm »
The lock out start + back as which requires a exit button that just sends back + start is a KADE fearure.
I think you have a good set of inputs for a 2 cab.
jammin0
« Reply #52 on: December 03, 2013, 12:22:03 am »
Staying alive.  Got some of the CP finished.  I still need to round down the front and route out a spot for the joysticks.
rablack97
« Reply #53 on: December 03, 2013, 12:21:34 pm »
What are the 4 buttons up to for?
Is that another in the center and 2 to the right as well?
Degenatrons pushed out a new update for the loader this weekend, you will need to grab that.  I pointed out a bug in the exit to dash, (wrong button combination)  so thats fixed now.
I also have a custom board, that allows you to autoconnect to the kade, without opening up the cab and pulling the kades out. You just plug into a USB port, Kade initializes, customize, program, unplug and done.  A cool feature you might think about adding...
I agree with Sharp though, 8 buttons is way too much, and with proper mapping you can nix the LR Triggers.
If your going with the shift button, make sure you wire up the external LED indicator.  You can install a seperate LED on the panel, or what i've done is get some clear IL button casings and solid color plunger.  Wired the led in the clear casing, so when the button is double clicked the casing lit up letting me know shift was enabled.
Also, Vision and Co5 standard are set up like so....
X  White Y
A  Black   B
This will give you the proper setup for all streetfighter type games
If you leave as is you will have to go into the CO5 or vision configs to match up what you have now....
Killer Instinct, set the config file under Udata to this for each player
2
5
3
0
4
1
you know what i'm talking about when you see it....
Not sure if your putting any fans in your build, but I'd be interested in how you get rid of the line noise that will show in your video.  It happens to all of my decased builds.  The only way i compeletely got rid of it was running the VGA to RGB video card off of a pc PSU, so it was getting clean power.
Also if your using a 1.1-1.3 xbox, when you decase you will notice 2 metal clips near the video input, that touch the metal case insert.  If you decase, and your video is scarambles, just solder 2 wires to those clips and solder the other end back to ground.  This was remedied in later xbox builds, but 1.1-1.3, the clips have to be grounded.
Also, peek through this thread, should give you some additional ideas....
http://forum.arcadecontrols.com/index.php/topic,123039.0.html
mike boss
« Reply #54 on: December 03, 2013, 12:47:47 pm »
I'm liking this project.
I plan on doing an XBOX project myself, also using a KADE so this is really good.
jammin0
« Reply #55 on: December 03, 2013, 02:22:41 pm »
They are for Shift - Back - Coin 1 - Coin 2
The front center are original Eject and Power buttons.  And on the right side I will have P3 and P4 controller ports.
Awesome, I'll have to get that.
I already have a breakaway to usb connector that I used before the 360 controllers came out in order to use my controller on the PC.  I think I can pretty easily just pop off the cable from the xbox and reverse it back to USB for updating them one at a time.  I will still have to go through the inside but I can leave the CP intact and just go through the back.
Thanks for reminding me of that, I actually have some cool indicator lights that were originally for automotive purposes that I got when the local electronics parts store went out of business.  I totally forgot to incorporate that into the design but it will probably work fine just to the left of the left most top admin button.
X  White Y
A  Black   B
I was actually just copying floriske.nl's layout but I guess I better get into the games and see what you're talking about.  Since it's a 2-player and 6 buttons I definitely want the fighters to work easily.  Does that mess up any of the other control schemes for Mame games or Consoles?  I better play around more on a controller before I commit.
I'm using straight component from the xbox as it is an LCD TV.  I'm hoping that I get a clean signal but I guess I'll have to wait and see.  I'm going to decase but I have tons of room so I will most likely just dremel off the sides and all the extra heatshielding to leave me with the console base and everything grounded in the same way it already is.  I'm going to run the original case fan as an intake and put another larger fan venting out at the top of the back access panel
I've read the whole thread, wish I had that guys pro routing skills.  In fact, I'm almost embarrased to make an xbox bartop after his.  Pure genius.
[/quote]
Thanks a ton for all the pointers, I'm excited to see this come together, and sad that I'm giving it away  :( as a Christmas gift.
rablack97
« Reply #56 on: December 03, 2013, 02:47:01 pm »
The custom board takes all of the extra out of the equation.  It uses neutrik pass thrus, so all your doing is plugging into the USB port.  No unplugging the Kades, it uses relays to shut off the data and power from the xbox when the pc is plugged in, then when its unplugged it reverts back to the xbox.
In other words, plug in Laptop, program, unplug laptop and done.
X  White Y
A  Black   B
No it doesnt mess up anything else, as you see A & B are still in tact, which is about it for most mame game.  Games like MK, you have to configure w/i mame to pick up the block as those were on the triggers.  The rest of the games work well with this setup.
Oh ok, your not using a monitor, so you should be cool all the way around.
Also, don't forget about the 3.3v standby, tap into that from the PSU to lite up your power and eject buttons prior to turning the system on...
jammin0
« Reply #57 on: December 04, 2013, 12:53:31 am »
I made the mistake of glueing the control panel before finishing routing everything out.  It's been a pain but I've had to route with my dremel.  I hacked up the original power and eject button and am going to light with the same light strips I'm using everywhere else.  In order to get it properly lit I drilled a couple of holes through the power board PCB so that I could shine through to the diffuser.  Here's a quick video clip.
rablack97
« Reply #58 on: December 04, 2013, 11:45:38 am »
 :applaud: :applaud:
mike boss
« Reply #59 on: December 05, 2013, 10:50:38 am »
I like what your doing with this project and I'm inspired to tackle one myself..........SOON!
I have the XBOX, the RGB led strips, and the KADE's !
I like what you did with the marquee.
Question, when you sand it how does it look when painted after ?
Does the paint look nice and smooth ?
Would it not be better to only sand one side, then paint the other ?
jammin0
« Reply #60 on: December 05, 2013, 11:26:42 am »
I should have it all painted by this weekend and I'll try to take some pictures with a real camera.  I think I understand what you're getting at with the marquee but I sanded both sides since I needed the paint to stick to the plexiglass on the outside.  Mostly I am using this method in order to create a seamless look with the plexiglass and the wood.  Alternatively, you could make a more traditional marquee that was framed by the wood or retainers or whatever and then diffuse the backside, mask the backside, and paint only the backside.  Since I'm painting the whole front I have to sand the front.  Sanding the back becomes a moot point since you won't see it anyway and I prefer to diffuse it as much as possible.  I'm impressed with how well the plexiglass diffuses with sanding both sides and then positioning the LEDs a few inches back.  I went ahead and cut out some circles of plexiglass for the side emblems in order to create the same exact effect.
I have to be careful not to build up the paint as much on the marquee area or it will be hard to get the masking off, also, while I can sand all the rest of the cab through the paint process, you can't really sand the marquee using this method as it would screw with the mask as well.
I'm hoping to achieve the same results as with my pedestal build in my signature.  It should look something like this:
« Last Edit: December 05, 2013, 11:30:25 am by jammin0 »
jammin0
Re: 2-player XBOX inspired Weecade inspired Bartop - Artwork Suggestions
« Reply #61 on: December 05, 2013, 09:08:28 pm »
So I'm trying to come up with some artwork to put into Vision for my menu screens and I'm having a rough time.  I tried grabbing some of the Hyperspin Genre pictures but they don't match up very well.  I like the Vision Genres so I'm trying to keep them similar.  The Menu Screens are these:
  • Arcade Classics
  • Action Games
  • Console Classics
  • Beat Em Ups
  • Fight Club
  • Racing
  • N64
  • Run N Gun
  • Shoot 3d
  • Shoot Em Ups
  • SNES
  • Sports Classics
  • Mega Man
  • Sega
  • Zelda
  • Xbox
Anyone have any great ideas on some simple menu screens?  Keep in mind I don't have the best artistic ability.  I was hoping to use previously created clipart and logos but I don't think it will flow or match very well.
jammin0
« Reply #62 on: December 06, 2013, 09:32:27 am »
The bartop won't have a really distinct color scheme since it is mostly black with the lights being the only thing that give it some color.  To go with that theme I thought of rainbows.  I'm not really sure how this will look until I stick it into Vision and see it but here it is.  The overlay with the video preview in the middle and the menu titles should show up above.   :dunno :dunno I might try a few more ideas before I commit.
The other pictures are some alternate overlays.
« Last Edit: December 06, 2013, 09:37:33 am by jammin0 »
rablack97
« Reply #63 on: December 06, 2013, 11:59:00 am »
looks like your going psychadelic like the Vision Box.....
You may hit-up dreygor in the Coinops Forum, he's good with art,  He and I came up with this for his Xbox vision project.
http://forum.arcadecontrols.com/index.php/topic,133965.msg1380687.html#msg1380687
You might see if drey will release his custom version of vision to you....looks like it would fit your build.
« Last Edit: December 06, 2013, 12:03:59 pm by rablack97 »
jammin0
« Reply #64 on: December 06, 2013, 03:09:28 pm »
That build of Vision looks pretty sweet.  I love the video title screens.  Your Vision Box is super awesome too by the way.  I'm starting to feel a little bit rushed in trying to finish this thing so I'll have to see what ideas get scrapped just in the interest of time but I think that I like this one enough that I'm going to have to build myself a second one.  Kudos on your awesome work. :applaud:
jammin0
« Reply #65 on: December 09, 2013, 10:45:37 pm »
Tired of the flashy lights yet?  I'm pretty much done with the outside, now I just have to wire everything up and fill it.  I don't have the best way to pick up the colors without the camera overexposing.  That's what's up with the lamp half-way through.  I needed something to hold the LEDs around the emblem so I used some plastic dish things I got from the dollar store painted white and glued in place as a sort of light box on the sides.  I'll try and get more pictures later.
jammin0
« Reply #66 on: December 14, 2013, 12:38:23 pm »
Did something a little unconventional to get my joysticks mounted.  I didn't want to deal with screw holes so I recess mounted on the underside and then made some little wooden brackets tha pin it in place and glue down.  Not the most serviceable but I could always use a chisel if I need them out of there. ;D
  • Last login:January 05, 2026, 03:14:20 pm
« Reply #67 on: December 14, 2013, 12:55:47 pm »
You won't need to remove them to service them, so all is well. :cheers:
jammin0
« Reply #68 on: December 18, 2013, 12:50:38 am »
I'm about half of the way through wiring up the control panel.  The KADEs sure are making it a breeze.  The DVD drive was a bit of a pain to get looking nice but I'm happy wih it.  I can't help but think that it is a ton of work for something that will probably not be used that often.  Oh well, I don't think it will be a huge deal once all is said and done.  I even have a picture of the inside but don't judge me.  Everything is fitting and secure, even if it looks a little crazy inside.  I originally was going to mount the case fan to the bartop case to suck air in but stuck it on the CPU heatsink only to find that it kept the CPU a ton cooler.  I recommend a CPU fan to anyone doing an xbox build.  Temperatures went from around 50 Celsius under load to right around 40.  I also heatsinked the GPU which is helping a ton to keep things cool.  One case fan up top to suck air out and it seems perfect.  I'm hoping to finish by the end of the week if I can figure out where to spray paint my bezel in the cold and humid weather we've been having.
. . .more to come
EMDB
  • Project RetroCade
« Reply #69 on: December 18, 2013, 03:31:22 am »
It's not that unconventional... I did the same but I used a removable metal bracket to fixate the sticks:
  • Last login:Yesterday at 12:18:36 pm
« Reply #70 on: December 18, 2013, 09:29:15 am »
I just use a longer shaft and then mount from underneath using wood screws.  No need to route anything and the screws are plenty sturdy without having anything on the top of the CP.
jammin0
« Reply #71 on: December 18, 2013, 10:29:26 am »
I debated doing that and would have on a 3/4" panel but using only 1/2" MDF makes me leery of something tearing out.  Maybe I'm just paranoid but I'm pleased how it turned out.  Wasn't too much extra work anyway.
« Reply #72 on: December 18, 2013, 11:35:09 am »
I use carriage bolts from the top.  ;D
jammin0
« Reply #73 on: December 22, 2013, 01:47:33 am »
Pretty cramped but everything fits just barely on the control panel.  Having done mostly controller pad hacks I must say that the KADEs are a breeze.  shift and indicator light work just as advertised.
sharpfork
    • KADE
« Reply #74 on: December 22, 2013, 02:05:05 am »
Looking good!  I'm glad our stuff is working for ya and a part of your project.
jammin0
« Reply #75 on: December 22, 2013, 10:22:15 pm »
Pretty much all the way done.  I need to fix a couple of things software wise but it's all wired up and working how it should.
« Last Edit: December 22, 2013, 10:41:05 pm by jammin0 »
ark_ader
  • I glow in the dark.
« Reply #76 on: December 23, 2013, 01:02:32 am »
Lovely job there.  Another fantastic Xbox project completed.
Congrats!  :applaud:
jammin0
« Reply #77 on: December 23, 2013, 11:05:57 am »
So, I used the black and white middle buttons in my setup but now I'm running into the issue that the fighters are mapped correctly but most other games are not.  Can anyone point me towards some information for remapping the other games?  I would at least like to get N64, and NES setup to match my layout.  If there is a separate core for NEO GEO too that could be setup that would make things better too.  Anyone seen a guide for this?
**edit.   After playing around with it, the  process to change key maps for each game individually is easy enough so that's what I've decided to do.
« Last Edit: December 24, 2013, 01:44:47 am by jammin0 »
jammin0
« Reply #78 on: December 23, 2013, 02:02:36 pm »
Congrats!  :applaud:
Thanks for the encouragement. It has been an enjoyable build.
  • Last login:Today at 06:49:53 am
« Reply #79 on: December 23, 2013, 03:04:34 pm »
Pretty sweet.
Another solid build!
