Author Topic: ipac2 ground connection  (Read 2585 times)
Richardgregory
  • Last login:November 17, 2021, 01:15:10 pm
« on: November 03, 2013, 04:44:04 am »
Hi all. I am wiring up the Ipac2 and am wondering if it'll be better - more tidy to make use of both ground terminals or daisy chain all the grounds and connect to just one of the ground connections of te ipac2.
Ie. I was thinking maybe I'd use player 1 ground terminal for player 1 buttons and payer 2 ground terminal for player 2 side of the buttons.
Re: ipac2 ground connection
« Reply #1 on: November 03, 2013, 07:12:04 am »
I don't think it really matters, but by using two grounds you can find a loose ground a lot easier, it will either be in P1 ground circuit or P2 ground circuit. Whereas if you use one ground then you have a lot more areas to check for loose connection.
I have never had a problem with loose grounds after the cab was "commissioned", but I always try to use two grounds, just to be more tidy looking if nothing else.
I have heard of folks using both grounds and connecting them together at the end of the loop, just to provide an alternate ground if one fails, but I would want to know right away if something in my wiring fails, whereas this method could cover up a problem until another problem surfaces.
