Author Topic: Spinner or Volume knob???  (Read 3558 times)
fogman
  • Last login:June 09, 2007, 03:56:32 pm
  • A Tale of Nocturnal Terror!!!
« on: November 21, 2003, 09:23:24 am »
Has anyone tried to use this as:
a) a volume control
b) a spinner
c) A Mame32 navigator.
http://www.griffintechnology.com/products/powermate/tips.html
You can get it for around $30 on Ebay.
I saw it and thought of a few ways to use it, but wanted to know if anyone has any experience.  For instance, can you mount it to a surface?
Chris
    • Chris's MAME Cabinet
Re:Spinner or Volume knob???
« Reply #1 on: November 21, 2003, 09:48:56 am »
It does not spin, so it would not be a good spinner.  I don't know of anyone who's tried it for anything else.
--Chris
--Chris
eightbit
  • Last login:September 07, 2019, 07:38:11 pm
  • My cab is never done...
« Reply #2 on: November 21, 2003, 09:57:19 am »
It won't work as a spinner but it could potentially be used in some spinner games. It would work with ikari warrior type games to rotate and fire. It could be used as a steering wheel for games that used a 270' wheel. For the cost though you could just buy a spinner.
My statements are my own opinions. They have the value that the reader gives them. My opinion of my opinion varies between foolish and brilliant and these opinions often change with new information.
NIVO
« Reply #3 on: November 21, 2003, 05:52:16 pm »
boy i'll tell ya, if that thing could be pushed like a button, I'd be playin Frontline all the time hehe!! :D
eightbit
« Reply #4 on: November 21, 2003, 06:42:46 pm »
It is a button.
CitznFish
  • Last login:November 13, 2024, 01:18:45 am
  • www.subvertcity.com - Prof. Strength Slackwear
« Reply #5 on: November 21, 2003, 08:30:32 pm »
user action send key what it does
Rotate Right     Alt+Right Arrow moves to next frame
Rotate Left       Alt+Left Arrow moves to previous frame
Click                 Spacebar play/pause
Click & Rotate Right     Ctrl+Alt+Right Arrow next clip
Click & Rotate Left       Ctrl+Alt+Left Arrow previous clip
Ooooh maybe it will work for frontline! Time to make a CP with swappable spinners! :D
« Last Edit: November 21, 2003, 08:31:01 pm by CitznFish »
NIVO
« Reply #6 on: November 21, 2003, 11:26:55 pm »
ahh sorry fellas didnt see the push button command, this thing could be a decent solution.
eightbit
« Reply #7 on: November 22, 2003, 09:38:04 pm »
Oscar sells a push button spinner...
CitznFish
« Reply #8 on: November 24, 2003, 10:34:07 am »
are you talking about the Discs of Tron push/pull spinner?
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #9 on: November 24, 2003, 10:41:33 am »
So this would be a paddle, not a spinner.
Jakobud
  • Last login:November 11, 2025, 01:07:55 am
« Reply #10 on: November 24, 2003, 03:36:51 pm »
Saw this thing a long time ago on www.thinkgeek.com .  I don't see anywhere that says that it doesn't spin 360 degrees.  Also, I dont think you can set it to work as the mouse anyways.  It says you can program it to do "any key press combonations (if you keyboard can do it, this thing can do it)"  so I don't think you can program it to act as a single axis of the mouse... :(
hyiu
  • Last login:August 29, 2014, 05:36:15 am
  • too many games... too little time....
    • www
« Reply #11 on: November 25, 2003, 02:40:38 pm »
ok... here's the deal...
I got one before... and it looks cool....
and material is nice.....
there's only 1 problem...
it sucks as a spinner....
it does spin 360.... you can keep on spinning in either direction... and yes... you push the thing... that is a button...
but if you use it to play mame.... its wayyyyyyyyyyy toooooooo slowwwwwwwww......
like for Arknoid.... you'll need to spin I donno how many full rev if you need to go from 1 side to the other....
just wayyyyyy tooooo slooowwwww to be even close to be playable... and I tried email customer support.... not much....
so... I ended up returning it....
good luck.... maybe with new drivers.... etc you can get lucky...
Another Brilliant mind ruined by education....  :p
aricade
  • Last login:August 15, 2004, 01:38:26 pm
  • Wamma langa ding dong!
    • Isaacade
« Reply #12 on: November 25, 2003, 03:06:48 pm »
couldn't you increase the sensitivity in mame for the mouse device??
Off all the things I've lost I miss my mind the most!!
aricade
    • Isaacade
« Reply #13 on: November 25, 2003, 03:08:27 pm »
OK Stupid me...
But Couldn't mame increase key press sensitivty...
Maybe...
Now I'm grasping...
Cheers,
Aricade
hyiu
    • www
« Reply #14 on: November 25, 2003, 03:15:37 pm »
tried everything....
including increasing / decreasing sensivity to huge / tiny values.... somehow its just not playable....
1 thing worth noting....
this thing can be used in PC and Mac....
and in Mac... theyhave a "mode" or dirver mode...
that it's suppose to act as a "temptest knob".....
but in PC... there's no such mode.... (at least at the time I bought it....)  >:( >:(
since I have a limited time for return or I'm stuck with it.... I returned it like in 5 days.....
didn't able to make it work within that time....
but I have to say.... other than that wire coming out from the side (which will be visible if you install on panel top....)
that thing is very soild build....
if you want to give it a shot and is able to make it work, plz post your findings....
hyiu
    • www
« Reply #15 on: November 25, 2003, 03:33:01 pm »
here is an old thread about this knob...
or try search powermate or griffin...
http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=2938
