Author Topic: Xin Mo 2 player controller bad??? (SOLVED)  (Read 3453 times)
emt380141
  • Last login:October 30, 2013, 04:34:03 pm
« on: October 23, 2013, 10:50:03 am »
Hello all.  Been reading a lot of info and learning from this site, and just recently put together a quick 2 player panel for my kids to tool around with.  anyhoo, in an attempt to not spend too much to make sure its not a total waste of money before i commit to a full cab, i purchased a xin mo 2player controller. wired it up and rechecked it 3x.  The pin out of course is totally different from what the instructions came with,so ive figured out which ones are all buttons and they work fine, but cannot figure out my directionals.  when i try to configure game settings via tab,  it will only register Right when i push stick right, and it trips the selection line into a continuous cycle of only going up the list while resting in neutral position. Hope that is understandable.... would u think the controller is bad at this point or something im missing here, and if so, which would be a good cost friendly option?  just need to run common SFII setup with 2 admins.   Thank you in advance.
« Last Edit: October 29, 2013, 11:46:58 am by emt380141 »
JDFan
Re: Xin Mo 2 player controller bad???
« Reply #1 on: October 23, 2013, 11:28:28 am »
Here's a pic of the layout according to Monster Arcades - (as you can see there are a few differences in the layout for P1 and P2 so it might be you have it wired incorrectly - 1 wire should go to the corresponding R,U,L,D and the second wire to the ground for each joystick connection.
emt380141
« Reply #2 on: October 23, 2013, 11:58:09 am »
so maybe im doing something wrong.  my kit came with 2 daisy chains.  i assume, 1 per player.  on player 1 side,
I have all 6 buttons and the joystick daisy chained to G above B8,   or should i use G above U?    or do i need a seperate ground for buttons AND joystick?
  • Last login:March 17, 2026, 03:35:03 pm
    • GroovyGameGear.com
« Reply #3 on: October 23, 2013, 12:09:18 pm »
Make sure none of the joystick switches have the input wire connected to the NC terminal, instead of the NO terminal as they should be.  Different devices handle simultaneous (and impossible) opposing directions in different ways.  This behavior could indicate this condition.
Also, try removing all of the input connections to the stick and test each switch individually to make sure all of them are working like they should.
emt380141
« Reply #4 on: October 23, 2013, 05:26:19 pm »
just to make sure, i can use either of the Grounds on either side of the board to daisy chain, right?
« Reply #5 on: October 23, 2013, 06:49:00 pm »
Grounds are all common, so yes.
emt380141
« Reply #6 on: October 29, 2013, 11:46:33 am »
Finally got around to playing with the cp some more and its working very well now.  Thank you RandyT!  :cheers:
One of my switches was funny. replaced, and rechecked 2x's.  all good now.  Thank you everyone else as well for the help.  you guys are all awesome.  :applaud:
Slippyblade
Re: Xin Mo 2 player controller bad??? (SOLVED)
« Reply #7 on: October 31, 2013, 08:03:38 pm »
Randy's good for that.  I really recommend his shop as well.  Good prices, good product, good support.
