Author Topic: T-Molding for quarter inch wood  (Read 2863 times)
cigardude
  • Last login:December 20, 2017, 01:29:48 pm
« on: October 15, 2013, 11:20:09 pm »
Hi everyone. I've been searching for some 1/4" t-molding but no luck. Has anyone ever used it before? Do you have any other suggestions to finish the edges?
  • Online Online
  • Last login:Today at 05:12:51 pm
Re: T-Molding for quarter inch wood
« Reply #1 on: October 16, 2013, 12:08:43 am »
How about something like GRE34078A.
eds1275
  • Rock and Roll!
« Reply #2 on: October 16, 2013, 02:38:07 am »
I would just get some regular and follow any one of the methods opn this site for trimming. The sharp chisel seems to be the most popular, but I have had luck with a veneer trimmer tool that only does one side at a time that is available at home depot for $7.
jdbailey1206
« Reply #3 on: October 16, 2013, 06:55:32 am »
My understanding is that they only sell .5" to 1.5" sizes.  I've never heard of anything as small as 1/4".  If its possible I would get 1/2" material for your build.  If you have already built your machine I would have to agree with eds.  But keep in mind if you go with a trimmer you won't have a smooth rounded edge.  It will be noticeable when you trim it.
« Reply #4 on: October 16, 2013, 08:40:56 am »
Use a round over bit with your router.
severdhed
  • RIP Dinosaur Hippo
« Reply #5 on: October 16, 2013, 09:52:43 am »
the biggest problem i would see with using t-molding on 1/4" wood is once you cut the slot, there would be hardly anything left.  most T-molding i've seen uses a 1/8" slot cutter, that would leave only 1/16" of wood on either side of the slot, which i can't imagine would be strong enough to hold up to anything.  I'd either look for a some type of glue on molding, or just use a round over bit on it.
eds1275
  • Rock and Roll!
« Reply #6 on: October 16, 2013, 06:15:30 pm »
1/8" slot cutter? Maybe for the run of the mill stuff you can find in the hardware stores, but I'm pretty sure the norm is 1/16 in this hobby.
Another option would be the stick on pin striping you can find in the automotive store, they may have something in that thickness and I bet if you seal the edge of the mdf/wood it will stick nicely and for a long time.
paigeoliver
  • Awesome face!
« Reply #7 on: October 16, 2013, 10:21:22 pm »
3/32" is the official size. Although quite a lot of people use 1/16" because you can get that size at Harbor Freight. If you use 1/8" you might have to glue the stuff down depending on which tmolding you end up with.
matt4949
« Reply #8 on: October 16, 2013, 10:26:15 pm »
I agree and make sure to seal the edge with thinned wood glue or bondo so that the paint does not fade over time or gets fat.
severdhed
« Reply #9 on: October 16, 2013, 11:50:22 pm »
you guys are right, my bad...it is a 1/16" slot, but that is still a significant portion of the 1/4" wood.  i wouldn't want to weaken it that much.
michelevit
  • Last login:December 25, 2024, 06:57:41 pm
« Reply #10 on: October 17, 2013, 12:15:13 pm »
Use edge banding instead of t molding.
Its even sold at home depot and a perfect way to seal the end of plywood.
Applies easily with a clothes iron and thin enough to be trimmed with a small plane or even a razor blade/exacto knife.
cigardude
« Reply #11 on: October 21, 2013, 09:40:44 pm »
Thanks for all of the great advice everyone. I think that I am just going to bite the bullet and make the sides and control panel from 1/2" wood so I can just stick on some regular T-Molding and call it a day.
