Author Topic: Coin Acceptor n00b!  (Read 4593 times)
patrik
  • Last login:October 16, 2013, 05:59:55 am
  • Are you keeping up with the Commodore?
    • xbo1k Network
Coin Acceptor n00b!
« on: October 15, 2013, 03:51:20 am »
Hey everyone! I'm new to building arcade machines, and I have purchased the parts for my machine. Currently I have with me: 4x buttons, 1x JS02 Zippy joystick, and my coin acceptor.
Everything is fine, except for the coin acceptor. I was expecting a simple mechanism that would allow you to select a coin size (which i have), and it would close a circuit (like pushing a button) to a key on my PC that I assign the "Coin inserted" button!
Instead, I have recieved a 4 pin connector as follows
pin 1 - Counter (+/-) AND DC +12V
pin 2 - Coin Signal
pin 3 - Ground
pin 4 - Counter (-/+)
Is this a simple Normal Open/ Normal Close system? or am I right?
What is Coin Signal? Someone help!!  :hissy:
(I would have read the instructions, but they are in terrible english!)
  • Last login:Today at 04:02:44 am
Re: Coin Acceptor n00b!
« Reply #1 on: October 15, 2013, 04:21:11 am »
Welcome aboard, Patrik.
Sounds like a CH-924 or CH-926.
Check out this thread and this one for details and a diagram on how to connect a zener diode to protect your encoder from the 12v in the mech.
blashyrk
  • Last login:May 14, 2017, 02:56:16 am
« Reply #2 on: October 15, 2013, 04:22:23 am »
I've got a similar coin acceptor, connect pin1 and 3 to a 12v power supply, and pin 2 and 4 to your encoder, but you have to connect a voltage regulator (zener diode) to get the voltage down to 5v or you will fry the encoder. I use a usb "hacked" usb gamepad for my coin mechs. Mines got a switch to select no/nc
patrik
    • xbo1k Network
« Reply #3 on: October 16, 2013, 05:55:02 am »
Hi thankyou for the replies. That diagram appears to be how my coin mech works.
Would I need the diode for an I-PAC2?
« Reply #4 on: October 16, 2013, 09:40:37 am »
YES, you will need to use a zener diode or the 12v from the coin acceptor will fry your IPac.   :bat
BTW a diagram almost exactly like the one Blashyrk posted is on this page on the Ultimarc (IPac manufacturer) site.
mgb2015
  • Newbie
  • Last login:June 23, 2015, 03:16:37 pm
« Reply #5 on: June 23, 2015, 02:29:52 pm »
I have the coin acceptor in the video. I'm trying to set it up so that the value of a coin entered is input as a keystroke to a PC. Any ideas please?
