Author Topic: ELMERS WOOD GLUE FOR SEALING UP MDF  (Read 14731 times)
matt4949
« on: October 06, 2013, 12:49:34 pm »
 Ok, so I read about this in another forum (they build speaker cabinets out of MDF).
Yesterday I cut a master template for a bartop build I'm working on and wanted to seal the template from moisture and any wear and tear it might encounter. I used a mixture of equal parts wood glue and water. Painted a coat on with a foam brush making sure to really get the cut edges saturated. Let it dry and then reapplied a second coat. Finished up with a quick sanding using 220 grit paper.
I know time will tell if this method is a good way to preserve MDF from wear and tear. I am very pleased with the way it looks and feels. Very "Rock Solid".
CaptainMarvel
  • Last login:May 03, 2020, 04:49:55 pm
Re: ELMERS WOOD GLUE FOR SEALING UP MDF
« Reply #1 on: October 06, 2013, 11:26:18 pm »
So the mixture wasn't sticky/tacky at all?
Is there any kind of "surface" to it at all when the solution dries?
SIDE NOTE:
Love the avatar  . . . . SHAZAM !!!!
TOM
Understanding that you may not see success instantly, but that all your good decisions add up to a cumulative success over time is what separates those who "get there" and those who don't. Every day you either get further away from your goals, or closer to them . . . Its up to YOU."
kahlid74
  • Gaming for a better future!
    • GamersAnon
« Reply #2 on: October 15, 2013, 03:51:21 pm »
Yeap, it works well.  I've also done polyurethane seals as well.  Typically I don't make molds out of MDF too often and when I do, the basement is regulated humidity wise so it's usually okay.
matt4949
« Reply #3 on: October 15, 2013, 04:50:04 pm »
Do you think 1/4 plexi would be better?
DarakuTenshi
    • Card Fighters Project
« Reply #4 on: November 09, 2013, 08:54:54 am »
What I use is Spackle and water. Mix it together to make a constancy that is like paint and go to town. Once it dries on the wood use a 300-400 sand paper on it and you have a nice finish that you can prime.
Locke141
  • Never grow up.
« Reply #5 on: November 09, 2013, 09:26:54 am »
I did this on my build. Seemed to work well.
shrunkenmaster
« Reply #6 on: November 10, 2013, 09:48:45 am »
Are you using this method instead of primer? Can you paint over this?
matt4949
« Reply #7 on: November 10, 2013, 10:19:15 am »
I am using it before primer. as a sort of mdf protectorent? I sweat a lot and it seems to keep stains from showing through the paint also when you drop a piece on it's edge there is no where near  the damage as on unprotected mdf.
mcseforsale
  • Creepy Mario Dude
« Reply #8 on: November 15, 2013, 12:09:26 pm »
I use wood glue for lotsa stuff.  MDF primer is interesting.  Armoring the cut ends of MDF is important in protecting a fresh cab.
AJ
WillyByte
  • Last login:August 21, 2022, 05:40:30 pm
  • These words should be replaced with better ones.
« Reply #9 on: February 17, 2014, 06:35:59 pm »
Matt, is it too soon to ask if you're still satisfied with wood glue as an MDF sealer?  I'm building my first arcade control box and have zero experience with sealing MDF.
dfmaverick
« Reply #10 on: February 18, 2014, 12:09:07 pm »
I recall your use of it on the Fistful of Quarters cab.
http://forum.arcadecontrols.com/index.php/topic,122362.msg1310052.html#msg1310052
  • Last login:Yesterday at 11:02:50 pm
« Reply #11 on: February 18, 2014, 12:13:51 pm »
Good information to know.  Looks like I'll be sealing up the cut edges on my pedestal.
mcseforsale
  • Creepy Mario Dude
« Reply #12 on: February 18, 2014, 12:35:34 pm »
I love glue.  It's why I live.
AJ
