Author Topic: Advice needed: Scratched LCD  (Read 1963 times)
ppv
  • Last login:October 16, 2020, 03:08:56 pm
  • The cheap@ss gamer
« on: October 02, 2013, 04:35:29 pm »
I've got a 19" monitor for really cheap to use in my cab. Only problem is it has two scratches on it. Mind you, they are minor ones, but knowing they are there are sure to drive me nuts. Before I learn to live with it, would any of you pros have any trick to hide or fix this? I already tried the eraser trick, but since my monitor has a matte surface, there is no layer to remove... There is also the vaseline method, but this is far from permanent.
Any of you guys know any trick to this?
Doing arcades, the cheap@ss way!
First Project : ttp://forum.arcadecontrols.com/index.php/topic,151071.0.html
Next one : The Token Muncher [urlhttp://forum.arcadecontrols.com/index.php/topic,135417.0.html[/url]
Re: Advice needed: Scratched LCD
« Reply #1 on: October 02, 2013, 04:37:54 pm »
cover the monitor with smoked plexi?
ppv
« Reply #2 on: October 02, 2013, 04:40:22 pm »
I hadn't though of that...  8)
BobA
  • What Me Worry?
« Reply #3 on: October 02, 2013, 06:02:54 pm »
I had a couple of good 19 inch 4:3 LCD monitors with scratches.   I used a new white pencil eraser.  They are medium sized and retangular in shape.  I worked on the scratches with patience and they soon became not noticeable.  I cleaned the screen and could not see where the scratches had been under clear plexi.
UFO
  • Last login:July 31, 2025, 01:00:25 pm
  • Im nearly out of unproductive things to do at work
« Reply #4 on: October 02, 2013, 07:10:47 pm »
Vaseline - I had quite a deep one on a monitor of mine and it works really well. Just rub it in and that's it.
It's not a permanent fix, but it does a pretty good job.
matt4949
« Reply #5 on: October 02, 2013, 07:24:28 pm »
There are some really good pieces of advise here. Thanks guys.
Fursphere
  • Last login:November 17, 2025, 08:30:46 am
« Reply #6 on: October 02, 2013, 08:21:34 pm »
Spend $85 and get a new one?
http://www.newegg.com/Product/Product.aspx?Item=N82E16824005499R
Scratches drive me insane.  :)
WindDrake
  • Last login:December 03, 2020, 09:49:05 pm
  • Electrical Engineer
« Reply #7 on: October 03, 2013, 12:11:26 am »
So long as you don't go so hard as to burn through the polarizer, you could use Novus #2 to polish the area in question, and cleanup with Novus #1.
Fursphere
« Reply #8 on: October 03, 2013, 07:14:38 pm »
Then you'll have a shinny spot on your matte screen.  :)
ppv
« Reply #9 on: October 04, 2013, 02:13:23 pm »
Thanks Guys, I think i'll try the vaseline coupled with the smoked plexi! :cheers:
  • Last login:Yesterday at 12:24:02 am
Re: Re: Advice needed: Scratched LCD
« Reply #10 on: October 04, 2013, 02:26:24 pm »
Sounds like one of Rick's kinky posts... :cheers:
CoryBee
  • Bopity Boopy
« Reply #11 on: October 04, 2013, 03:01:39 pm »
My thoughts exactly
