Author Topic: IPAC2 ground question  (Read 1690 times)
swindmiller
  • Last login:July 31, 2014, 08:23:51 pm
« on: September 19, 2013, 12:10:27 pm »
I just successfully replaced the crappy board in my Tankstick with an IPAC2. The IPAC has 2 ground terminals but does it matter what you ground where? It was easier for me to daisy chain 2 more buttons on one side then the other. Does that make a difference?
Everything is working fine and I am 99% sure it's fine but just figured I would check.
Thanks,
Brian74
  • Yep... I built that!!
Re: IPAC2 ground question
« Reply #1 on: September 19, 2013, 12:41:05 pm »
Fair as I know, you dont have to have the same number of buttons per side ::)
Sent from my SGH-M919 using Tapatalk 2
  • Last login:Yesterday at 11:55:07 pm
« Reply #2 on: September 19, 2013, 01:12:47 pm »
Unlike the X-Arcade encoder that uses a separate ground for each connector, the IPac uses one ground connected to several terminals.
As you thought, there is no need to "balance" the number of buttons on ground terminals.
swindmiller
« Reply #3 on: September 19, 2013, 01:37:20 pm »
Great...thanks. Everything works much better with the ipac  :applaud:
