Author Topic: feature request  (Read 2328 times)
pucci
  • Last login:November 30, 2025, 10:09:53 am
feature request
« on: September 14, 2013, 06:01:59 am »
can you add this two great feature to GroovyMAME?
- Skip Startup Frames
- No Validity Checks
http://forum.arcadecontrols.com/index.php?topic=133643.0
  • Last login:Yesterday at 10:56:16 pm
Re: feature request
« Reply #1 on: September 21, 2013, 01:10:11 pm »
Hi pucci,
Thanks for posting about this feature. However, I'd rather not adding patches that modify the official drivers when possible.
pucci
Re: feature request
« Reply #2 on: September 21, 2013, 01:53:15 pm »
i dont' think that this patch touch driver
  • Last login:Yesterday at 11:06:35 pm
Re: feature request
« Reply #3 on: September 21, 2013, 01:57:19 pm »
Sure it does. That's why you have to roll your own if you want it.
pucci
Re: feature request
« Reply #4 on: September 22, 2013, 06:11:07 am »
I do not understand why you answer me so rude, why do you say that the patches go to modify the drivers?
skipStartUpFrames.txt modify video.c
--- old/emu/video.c 2013-01-11 07:32:48.000000000 -0800
+++ src/emu/video.c 2013-07-28 22:58:13.000000000 -0700
@@ -224,6 +224,20 @@
  // only render sound and video if we're in the running phase
  int phase = machine().phase();
  bool skipped_it = m_skipping_this_frame;
+ static int Frames=0;
+ int skip_startup_frames = 999;
+ if (skip_startup_frames)
+     Frames++;
+         if (Frames<=skip_startup_frames)
+           skipped_it = true;
+         if (Frames>skip_startup_frames+2)
+           skip_startup_frames=0;
  if (phase == MACHINE_PHASE_RUNNING && (!machine().paused() || machine().options().update_in_pause()))
  bool anything_changed = finish_screen_updates();
validityChecks.txt modify mame.c
--- old/emu/mame.c 2013-07-28 21:23:24.000000000 -0700
+++ src/emu/mame.c 2013-01-11 07:32:48.000000000 -0800
@@ -171,8 +171,8 @@
  // otherwise, perform validity checks before anything else
  if (system != NULL)
- validity_checker valid(options);
- valid.check_shared_source(*system);
+// validity_checker valid(options);
+// valid.check_shared_source(*system);
  // create the machine configuration
