Author Topic: [Rodotron 666B-29] Please help me create my monitor preset  (Read 19934 times)
  • Last login:Yesterday at 06:10:10 am
Re: Please help me create my monitor preset
« Reply #40 on: September 17, 2013, 02:35:41 pm »
Try increasing the 31 kHz range a little bit:
crt_range2  31000.00-32500.00,50.00-65.00,0.330,3.580,1.750,0.316,0.063,1.137,0,0,480,512,0,0
rock145
  • Last login:November 07, 2021, 02:05:20 pm
« Reply #41 on: September 17, 2013, 02:55:19 pm »
Thanks calamity for your help and patience. That last range work perfectly with those two games that had wrong
resolution. So it's save to say that this is the best preset for rodotron 666b: :afro: :cheers: :burgerking: :applaud: ;D
monitor custom
crt_range0  15450.00-16050.00,50.00-65.00,3.190,4.750,6.450,0.191,0.191,1.164,0,0,192,288,448,576
crt_range1  23900.00-24900.00,50.00-65.00,2.870,3.000,4.440,0.451,0.164,1.148,0,0,384,400,0,0
rock145
« Reply #42 on: September 17, 2013, 03:01:37 pm »
I would like to know if it is possible to make a v-size, v-hold, v-space, h-space feature integrated in groovymame in a future release. Even thought I now
have a preset if I increase the size of some games the others look zoom and with thick scanlines. But if the software does it there no need to mess  around with it. ;)
« Last Edit: September 17, 2013, 03:33:32 pm by rock145 »
Re: [Rodotron 666B-29] Please help me create my monitor preset
« Reply #43 on: September 17, 2013, 04:36:35 pm »
I just modified the first post topic to include "Rodotron 666B-29" so its more informative. I'm glad to see that you found a good preset for your monitor. Unfortunately v-size and v-hold can't be controlled by modelines. This is something that must be done physically on the monitor. We all have to deal with this. On the othern hand horizontal/vertical centering and horizontal size can be controlled by modelines.
rock145
« Reply #44 on: September 17, 2013, 04:51:31 pm »
Thanks calamity. I guess this is an anolog trisync that does not remember resolutions. I am gonna leave it at a size that is good for all res
so I don't have to keep using v-size between games. The preset does help a lot with vertical games.
rock145
« Reply #45 on: September 17, 2013, 05:11:33 pm »
« Last Edit: September 23, 2013, 03:22:41 pm by rock145 »
rock145
« Reply #46 on: September 23, 2013, 03:23:00 pm »
Today I received Scanline Generator SLG3000 and was impress on how good I was able to control scanlines with groovyume. The reason that I bought it was because I don't like how thick the scanlines are on my monitor cga games. I did arcade_31 on groovyume.ini however, I am having the same issue as before where some vertical games come out cropped in the middle. Would it be possible to make a preset that exploits 31 kHz signal? or is there a way to let groovyume change resolutions without producing scanlines and let SLG3000 poroduce it but still change resolutions.
« Last Edit: September 23, 2013, 03:47:33 pm by rock145 »
blontic
  • Last login:December 21, 2020, 08:03:28 am
« Reply #47 on: September 24, 2013, 03:47:51 am »
monitor custom
@Calamity can you tell me if these settings are the same as the preset you have in the ini file for the WeiYa 3129 since it's the same chassis as the rodotron? Just wondering what I should use for my WeiYa.
rock145
« Reply #48 on: September 24, 2013, 03:00:23 pm »
Solve the problem with cropped vertical games in the middle. The problem was using arcade_31 after I change it to custom it got fix. However,
I wanted to used 31 kHz signal with slg3000 because I was unhappy of how thick the 15 kHz signal is with my multisync monitor. After playing around with groovyume.ini I left the monitor type as custom and in resolution I put 720x480@60 and it open up the 31 kHz signal ignoring the cga signal which I wanted. I check some of the games and these are some of the resolutions I am getting with some games. 400x480p, 512x480p, 888x480p 704x480p, 960x480p, 576x480p, 832x480p, 400x480p, 592x480p, 768x480p and 736x480p. I am much happier with the way cga games look now, when the monitor used to change to 15 kHz signal and I could not make out the faces of characters because of the thickness of the scanlines now it looks just right. I thought that all the games where gonna be display at 720x480p fix resolution but it turns out that swichtres is changing res and my slg3000 is producing the scanlines.
« Last Edit: September 24, 2013, 03:05:34 pm by rock145 »
rock145
« Reply #49 on: September 24, 2013, 03:09:22 pm »
monitor custom
I say you can try it out there's nothing wrong with this preset for rodotron 666b-29 I am using it  and works great.
« Last Edit: September 24, 2013, 03:15:16 pm by rock145 »
rock145
« Reply #50 on: September 25, 2013, 03:48:46 pm »
I just finished checking all the mame games with the 31 khz signal. All games switch
resolutions using the 31 khz. However, these are the only games that are still using the 15 khz
signal. I want groovyume to display all games at 31khz ranges because I don't like the
way games look at 15khz with my monitor. Here is the list of games I want to be display
in 31khz.
athena,canvas croquis,country club, fighting golf, gladiator 1984, madcrasher, main event 1984
rubio lepus, super volleyball.
288x216 (H) 60.000000 Hz
switchres: 576x480i 60.000 HZ 15.930 khz
bank panic
224x224 (H) 61.034092 HZ
switchres: 446x480i 60.566 hz 16.080 khz
champion boxing,champion pro wrestling, Doki doki penguin land
280x216 (H) 59.922738 hz
switchres: 560x480i 59.923 hz 15.909 khz
cisco heat
256x216 (H) 30.000000 hz
switchres: 512x480i 60.000 hz 15.930 khz
combat hawk
224x224 (v) 61.034091 hz
switchres: 800x480i 60.566 hz 16.080 khz
dribbling
256x216 (H) 60.000000 hz
switchres: 512x480i 60.000 hz 16.930 khz
momoko 120%
240x216 (H) 60.000000 hz
switchres: 480x480i 60.000 hz 15.930 khz
ninja mission, roadwars,side winder(arcadia, set 1 v2.1), spot (arcadia, v 2.0),
space ranger (arcadia v 2.1),sportime table hockey(arcadia, set 1, v 2.1), sportime bowling(arcadia, v 2.1)
up scope, world darts(arcadia, set 1, v 2.1), world trophy soccer(arcadia, v 3.0), xenon (arcadia, v 2.3)
671x216 (H) 59.997000 hz
switchres: 1344x480i 59.997 hz 15.929 khz
penguin adventure,pesadelo
I open the 31 khz signal by putting 720x480@60 resolution in my ume.ini and using the last
rodotron 666b preset please take a look. The other way would be to put arcade_31 but it makes
some vertical games cropped this is the only way to get around it so far.
also look at the logs for these games. I also tried increasing crt_range2 00-33000
crt_range2  31000.00-33000.00,50.00-65.00,0.330,3.580,1.750,0.316,0.063,1.137,0,0,480,512,0,0
but it did not help.
Thanks.
# CORE CONFIGURATION OPTIONS
readconfig                1
writeconfig               0
# CORE SEARCH PATH OPTIONS
rompath                   W:\Emulation\UME\roms\mame;W:\MameUI32 Plus 1.43\roms;W:\Emulation\UME\roms\mess
hashpath                  hash
samplepath                samples
artpath                   artwork
ctrlrpath                 ctrlr
inipath                   .;ini
fontpath                  .
cheatpath                 cheat
crosshairpath             crosshair
# CORE OUTPUT DIRECTORY OPTIONS
cfg_directory             cfg
nvram_directory           nvram
memcard_directory         memcard
input_directory           inp
state_directory           sta
snapshot_directory        snap
diff_directory            diff
comment_directory         comments
hiscore_directory         hi
# CORE STATE/PLAYBACK OPTIONS
state
autosave                  0
playback
record
mngwrite
aviwrite
wavwrite
snapname                  %g/%i
snapsize                  auto
snapview                  internal
burnin                    0
# CORE PERFORMANCE OPTIONS
autoframeskip             0
frameskip                 0
seconds_to_run            0
throttle                  1
syncrefresh               0
sleep                     1
speed                     1.0
refreshspeed              0
# CORE ROTATION OPTIONS
rotate                    1
ror                       0
rol                       0
autoror                   0
autorol                   0
flipx                     0
flipy                     0
# CORE ARTWORK OPTIONS
artwork_crop              0
use_backdrops             0
use_overlays              0
use_bezels                0
use_cpanels               0
use_marquees              0
# CORE SCREEN OPTIONS
brightness                1.000
contrast                  1.000
gamma                     1.000
pause_brightness          0.65
effect                    none
# CORE VECTOR OPTIONS
antialias                 1
beam                      1.0
flicker                   0
# CORE SOUND OPTIONS
sound                     1
samplerate                48000
samples                   1
volume                    0
# CORE INPUT OPTIONS
coin_lockout              1
ctrlr
mouse                     0
joystick                  1
lightgun                  0
multikeyboard             0
multimouse                0
steadykey                 0
ui_active                 0
offscreen_reload          0
joystick_map              auto
joystick_deadzone         0.3
joystick_saturation       0.85
natural                   0
joystick_contradictory    0
coin_impulse              0
# CORE INPUT AUTOMATIC ENABLE OPTIONS
paddle_device             keyboard
adstick_device            keyboard
pedal_device              keyboard
dial_device               keyboard
trackball_device          keyboard
lightgun_device           keyboard
positional_device         keyboard
mouse_device              mouse
# CORE DEBUGGING OPTIONS
log                       0
verbose                   0
update_in_pause           0
debug                     0
debugscript
debug_internal            0
# CORE MISC OPTIONS
bios
cheat                     1
skip_gameinfo             0
uifont                    default
ramsize
confirm_quit              0
ui_mouse                  0
autoboot_command
autoboot_delay            2
autoboot_script
# CORE MKChamp OPTIONS
disable_hiscore_patch     0
disable_nagscreen_patch   1
disable_loading_patch     1
# CORE SWITCHRES OPTIONS
modeline                  1
monitor                   custom
orientation               horizontal
connector                 auto
interlace                 1
doublescan                1
cleanstretch              0
changeres                 1
powerstrip                0
lock_system_modes         1
lock_unsupported_modes    1
refresh_dont_care         0
dotclock_min              0
sync_refresh_tolerance    2.0
frame_delay               0
lcd_range                 auto
crt_range3                auto
crt_range4                auto
crt_range5                auto
crt_range6                auto
crt_range7                auto
crt_range8                auto
crt_range9                auto
# WINDOWS DEBUGGING OPTIONS
oslog                     0
watchdog                  0
debugger_font             "Lucida Console"
debugger_font_size        9
# WINDOWS PERFORMANCE OPTIONS
priority                  0
multithreading            1
numprocessors             auto
profile                   0
bench                     0
# WINDOWS VIDEO OPTIONS
video                     d3d
numscreens                1
window                    0
maximize                  1
keepaspect                0
prescale                  1
waitvsync                 0
menu                      0
# DIRECTDRAW-SPECIFIC OPTIONS
hwstretch                 1
# DIRECT3D-SPECIFIC OPTIONS
filter                    0
# DIRECT3D POST-PROCESSING OPTIONS
hlsl_enable               0
hlslpath                  hlsl
hlsl_ini_read             0
hlsl_ini_write            0
hlslini                   %g
hlsl_prescale_x           0
hlsl_prescale_y           0
hlsl_preset               -1
hlsl_write
hlsl_snap_width           2048
hlsl_snap_height          1536
shadow_mask_alpha         0.0
shadow_mask_x_count       320
shadow_mask_y_count       240
shadow_mask_usize         0.09375
shadow_mask_vsize         0.109375
curvature                 0.0
pincushion                0.0
scanline_alpha            0.0
scanline_size             1.0
scanline_height           0.7
scanline_bright_scale     1.0
scanline_bright_offset    0.0
scanline_jitter           0.0
defocus                   0.0,0.0
converge_x                0.0,0.0,0.0
converge_y                0.0,0.0,0.0
radial_converge_x         0.0,0.0,0.0
radial_converge_y         0.0,0.0,0.0
red_ratio                 1.0,0.0,0.0
grn_ratio                 0.0,1.0,0.0
blu_ratio                 0.0,0.0,1.0
saturation                1.0
offset                    0.0,0.0,0.0
scale                     1.0,1.0,1.0
power                     1.0,1.0,1.0
floor                     0.0,0.0,0.0
phosphor_life             0.0,0.0,0.0
# NTSC POST-PROCESSING OPTIONS
yiq_enable                0
yiq_cc                    3.59754545
yiq_a                     0.5
yiq_b                     0.5
yiq_o                     0.0
yiq_p                     1.0
yiq_n                     1.0
yiq_y                     6.0
yiq_i                     1.2
yiq_q                     0.6
yiq_scan_time             52.6
yiq_phase_count           2
# VECTOR POST-PROCESSING OPTIONS
vector_time_scale         0.0
vector_time_period        0.1
vector_length_scale       0.9
vector_length_ratio       4.0
# BLOOM POST-PROCESSING OPTIONS
vector_bloom_scale        0.3
raster_bloom_scale        0.25
bloom_lvl0_weight         1.0
bloom_lvl1_weight         0.21
bloom_lvl2_weight         0.19
bloom_lvl3_weight         0.17
bloom_lvl4_weight         0.15
bloom_lvl5_weight         0.14
bloom_lvl6_weight         0.13
bloom_lvl7_weight         0.12
bloom_lvl8_weight         0.11
bloom_lvl9_weight         0.10
bloom_lvl10_weight        0.09
# PER-WINDOW VIDEO OPTIONS
screen                    auto
aspect                    auto
resolution                720x480@60
view                      auto
screen0                   auto
aspect0                   auto
resolution0               auto
view0                     auto
screen1                   auto
aspect1                   auto
resolution1               auto
view1                     auto
screen2                   auto
aspect2                   auto
resolution2               auto
view2                     auto
screen3                   auto
aspect3                   auto
resolution3               auto
view3                     auto
# FULL SCREEN OPTIONS
triplebuffer              0
switchres                 1
full_screen_brightness    1.0
full_screen_contrast      1.0
full_screen_gamma         1.0
# WINDOWS SOUND OPTIONS
audio_latency             2
# INPUT DEVICE OPTIONS
dual_lightgun             0
« Last Edit: September 25, 2013, 04:17:42 pm by rock145 »
« Reply #51 on: October 02, 2013, 04:43:48 pm »
Hi rock145,
The solutions is pretty obvious, just allow your monitor to use the 31 kHz range. The way you have it now you still are including the 15 kHz and the 31 kHz as selectable by GroovyMAME through the crt_range0 and crt_range1 lines. You have to set everything to 'auto' except crt_range0, which you have to replace with the 31 kHz range contents, like this:
crt_range0  31000.00-32500.00,50.00-65.00,0.330,3.580,1.750,0.316,0.063,1.137,0,0,480,512,0,0
rock145
« Reply #52 on: October 03, 2013, 09:48:57 am »
Hi rock145,
Thanks calamity I really do appreciate your help. You have help me achieve everything that I wanted out of my monitor. I would say that this is the
best forum for everything arcade. Without groovymame to me the arcade experience is not complete. :applaud:
