Author Topic: Player one push button  (Read 1498 times)
StragoRx
  • Last login:July 05, 2014, 05:56:09 pm
« on: August 28, 2013, 11:11:52 pm »
I just finished wiring my CP and everything is great except my P1 start push button only activates when I release the button (after I press it down and it pops back up I get signal), I know this is not a big deal because you never really need to hold it down for anything, but what should i trouble shoot?. I use the Ipac-2 and I i am sure its not the microswitch because i changed that out to see.
Re: Player one push button
« Reply #1 on: August 28, 2013, 11:26:33 pm »
No, I'm pretty sure that's right. The I-Pac P1 acts a a shift button.
StragoRx
« Reply #2 on: August 28, 2013, 11:31:49 pm »
I thought about that while I was at work, if so that's good to know...just didn't want anything to be shorted or whatever..
  • Last login:Today at 02:27:03 pm
« Reply #3 on: August 29, 2013, 12:10:33 am »
Yotsuya nailed it.
Since the IPac uses P1 Start as the shift button, it doesn't output the keystroke until the button is released because you may be trying to use a shifted function like P1 Coin before starting a 2 player game, etc.
The KeyWiz and KADE both have a dedicated shift input. (Shazaaam! and HWB respectively)
A dedicated shift input doesn't have an associated unshifted keystroke to delay until the button is released.
« Reply #4 on: August 29, 2013, 02:28:26 am »
You don't have that button wired on the NC (normally closed) contact do you?
« Reply #5 on: August 29, 2013, 03:21:21 am »
Sorry, but no chance he has it wired wrong.
What he described is exactly the way the I-Pac and Mini-Pac behave.
Most people never notice because they press and release the button quickly.
If the Mini-Pac/I-Pac didn't wait until P1 Start is released to send the keystroke, picture this scenario:
   * You want to play a 2 player game.
   * You already have one credit.
   * You want to use a shifted function for a second coin-up.
- Action (keystroke sent -- result)
- Press and hold P1 Start (1 -- 1-player game would start using the credit that you already had)
- Press P1 Button1 (5 -- a credit is added due to the shifted function)
As you can see, the I-Pac/Mini-Pac has to wait until P1 Start is released or another button is pressed to determine if the player intends to do P1 Start or a shifted function.
The only way around the delayed keystroke is to use a dedicated shift input with no associated keystroke like the KeyWiz Shazaaam! or the KADE HWB.
« Last Edit: August 29, 2013, 03:42:11 am by PL1 »
